Question about Polaroid Tablet Computer PMID701
Polaroid PMID 800, it wasn't charging at all, I pulled apart the case and looked around and then plugged the power supply back in and now I'm getting a flashing red light. Is that a good sign ?
The tablet is not staying charge and I find that's the problem is inside the whole where you put the charger
Usually it is.. this equipment is a very low quality Chinese one. I solved using a different connector from one universal Targus power supply for laptops. But it could cost you more than buying a new tablet. However, if you need to extract some info from it and you don 't want to use an additional power supply, there is a way to put a tiny aluminum band paper around the plug to press the contact inside. That will last while you don't pull the plug again... very impractical but only for emergency.
Feb 16, 2015 | Proscan 7-Inch Android Internet Tablet,...
Hi i have a samsung tablet gt-p5210 &it keeps shutting down sometimes i go to play a different game &it just shuts off help!!! Thanks
specify weather it is plugged in or not when this happens and if the battery is above 30%
if plugged in, is the plug getting loose if so replace the wire that charges it and plug will be tight again . clean around plug with folded paper corner to be sure nothing is inside pressed to back of plug slowly shorting power. batteries do wear out in these things so only plug back into charge when it is below 20% and let it charge all the way up. as each partial charge cost you one of the 1000 charges in the battery's life. get Battery Doctor from the play store it will trickle charge at end of cycle and will tell you the battery's health. good app.
Dec 17, 2014 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
Polaroid pmid705 black audio jack dosent work/sounds like **** since it was opened, what do I do
That is definitely a hardware issue. Polaroid, Emerson, Uniden, etc tablets are made in China under the same manufacturer. Just call there customer service and arrange for a replacement. You might or might not get the same model so be sure to clear that on phone itself. There customer service team is ok and you can ask for an upgrade if same model is not available
Mar 24, 2014 | Polaroid Tablets & eReaders
Polaroid tablet reset PMID 4312
when i trun on my tablet all it does is have the word POLAROID an it will not come all the way on what can i do
Dec 12, 2013 | Tablets & eReaders
Tablet wont charge
I had this problem. I took apart the two sections of the charger plug and there were two silver wires in there. I thought they were leaning a bit together, so I just gently pulled them apart a little, put it all back together, and it works. Asus tablet, also dock, always charge successfully since. I hope yours does too if you try this.
Sep 11, 2013 | ASUS Eee Pad TF101B1 Tablet
How can I fix the charging port on my Dell Streak 7?
Ok this is not a easy fix. The replacement port connectors are easy to get and cheap $4-$10. How ever they require that you are able to take apart the tablet unsolder the old port and then solder in the new one.
There are several places that will do this as a service but it ain't cheap. One place shows $299 for board repairs.
http://www.portatronics.com/index.php?cat=c295_Dell-Streak-7.html&XTCsid=vo7vc1f8r011l9e4p6e1bq34e3
If you search for "dell streak charging port repair service" you may find one closer or cheaper. It is possible that you can find a good board by searching for streak repair parts.
Make sure you know what replacement costs are for the unit. On some of these repairs you can come close to spending what you would for a new unit. So be careful about that.
Mar 21, 2012 | Dell Streak 7 Tablet Android
Polaroid Tablet Computer PMID701 Logo
Top Polaroid Tablets & eReaders Experts
John mullen
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
