Question about AUVIO Stereo Wireless Headphones
Pairing I plugged in the AUVIO stereo receiver via L/R RCA output. How do I pair the plantronics backbeat go earphones? I can't put in a code to pair them
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Unable to conenct to laptop
Performing a system reset might take care of the problem. Reset instructions: Plug in the AC charger and hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903 User's Guide for more information.
Plantronics Backbeat 903 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
Hi, I buy a new Plantronics Backbeat 903, but right now it's unrecognizable by any movile, can you give some hints on how to fix that problem. I try with an LG P500 and Nokia 6110, no answer...
Delete the device from the phone, then re-pair the headphones with the phone. If you just turn on the headphones, the device cannot connect because the headphones store the information that you already deleted it on the phone. To pair again with the other device (like a computer, phone, etc) you need to turn off the headphones, then turn on the headphones but press the power/pair button and hold until the led flashes red and blue (like 10 sec after the led turn only blue) to put it in discovery mode. Then turn on your phone and follow the instructions for finding (discovering) your bluetooth headset.
May 06, 2011 | Plantronics Backbeat 903 Bluetooth...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Mar 12, 2011 | Plantronics Backbeat 903 Bluetooth...
I just purchased Plantronics BackBeat 906 and am receiving sound only from one earpiece. Is there a setting that I am not aware of that could be causing this problem?
I would try the reset option listed in Plantronics user guide. Here are the steps for the reset and I will include the link to the user guide also.
Instructions to Perform a system reset:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jan 28, 2011 | Plantronics Backbeat 903 Bluetooth...
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it...
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Oct 12, 2010 | Plantronics Backbeat 903 Bluetooth...
AUVIO Stereo Wireless Headphones Logo
Top AUVIO Audio Players & Recorders Experts
 Mikey
Mikey
L Pfaff
L Pfaff
Vladimir Frolov
Are you an AUVIO Audio Player and Recorder Expert? Answer questions, earn points and help others
