Question about Honeywell Programmable Thermostat Heater
Biasi combi boiler with red light flashing at honeywell r6660d
Hi could you help i have no manual to the r6660d
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
Here is the biasi site that should have your manual. With no model number, I hope this helps.
Posted on Feb 17, 2014
Diagram honeywell wireless room thermostat system boiler model r6660d
Honeywell web site will have all the information you need.
Jan 02, 2014 | Heating & Cooling
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
HOW TO WORK THE TIMER
I couldn't find the exact match for your boiler but I have included the website for you. Since you have the product right there, you will probably have better luck. If you can't find what you need, then use the contact info and give them a ring.
http://www.biasi.co.uk/frameset_acro.htm
Apr 07, 2009 | Water Heaters
Red LED on honeywell r6660d
The problem is that the 2 units are "not speaking to each other". this could be caused by low batteries or a loss in signal caused by a powercut or an objection in the way of the 2 units.
first you need to turn the power off to the r666od (or otherwise known as the HC60NG) for 10 secs, then turn back on. then hold the grey button in for 15 secs. release then hold in for a further 5 secs.
go to the honeywell cm61 press the off button. hold temp up. temp down and prog 1 in for 3 secs until the dipslay goes to INST. at this point release all 3 buttons then press the i button until a beacon starts flashing.
this is now the end to your problem.
N.B the reason the green light was on is because the man override button will have been pressed.
hope this helps
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
582 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
