Msi charger Plugged in no charging
  • 128 Answers
It's either computer connector problem, or charger connector cable problem, or broken cable, or broken charger, or loosen connection between wall cable and charger, or charger to wall cable, or battery problem.....
if it runs, but not charging, I assume it can be battery issue...
Posted on Mar 25, 2014
Msi gt780dxr
Could be an actual problem with the power suppy ( power brick ) thats the first thing I would check.
Watch this video
How to test a power brick
If your power adapter is dead, then replace it. If its not then you have a problelm with your power connector which could need re-soldering on the motherboard, or you could have a problem with your computers motherboard.
Good Luck!
Jan 16, 2014 | MSI Computers & Internet
Charging port repair
there may be two problems...
1.) your charger may be too old, So first check your charger, on another laptop. If you don't have another laptop of same cord.Then replaced your charger from new one...
2.) you laptop may be too old or you use it very roughly. by this charger area get dusted. So you need to just clean your laptop internally. And especially from the cord area portion of the laptop.
Jun 11, 2013 | MSI S6000 WITH INTEL CORE I5-450M 2.4GHZ,...
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Msi laptop not charging/no power to good new charger
The DC jack in the laptop is a common source of trouble, from no power to intermittent operation. The computer will need to be dismantled down to the motherboard level to access the part.
May 22, 2012 | MSI Wind U100-280US Netbook
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
Notebook msi u230 says plugged in not charging and the adapter is good
Turn off your laptop first, then remove the battery. Plug the charger then turn on your laptop wait until it loads completely then put back the battery on your laptop while it's on.
I hope it will work for you.
Sep 21, 2011 | MSI U230 Light087 Netbook
My charger is plugged in to my MSI U130 netbook and in to the wall but is not charging at all. It isn't coming up with the little image to show the charger is plugged in, I have tried plugging the...
There are two very common faults that often cause this.
One is a damaged cord on the charger.
The other is a damaged connector on the laptop.
You will need a volt/ohm meter to test the charger. If you don't have one perhaps a friend does?
If you think you may have use for one inexpensive models are available and are fine for simple jobs and occasional use.
The charger's output voltage will be listed on the charger body. Look for something like:
OUTPUT: +19V 2000mA
For your purposes all you need to know is, is the charger putting out the proper voltage and is it steady?
If the charger is working then it is very likely the connector on the laptop.
These are not difficult to fix if you have experience repairing laptops.
Most computer repair people do this all the time for a reasonable set fee.
Hope this helps
Jul 03, 2011 | Computers & Internet
Problems with USB port and charging mp3 player with MSI Wind U120
do the usb ports work at all, if not open the case and see if there is a loose wire.
Jul 16, 2009 | MSI WIND U100 Notebook
Battery is not charging when plugged
It is critical that you report early problems immediately to the manufacturer, some like DELL have a 15 day return policy. Otherwise you must follow their warranty repair instructions. Could be the battery, the charger or the motherboard.
Jan 23, 2009 | MSI Megabook M670-046US Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
