Question about Honeywell Programmable Thermostat Heater
Wiring from r6660d to biasi combi boiler - Honeywell Programmable Thermostat Heater
proton77
  • 1183 Answers
SOURCE: Need wiring diagram to include: Underfloor
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: red LED on honeywell r6660d
The problem is that the 2 units are "not speaking to each other". this could be caused by low batteries or a loss in signal caused by a powercut or an objection in the way of the 2 units.
first you need to turn the power off to the r666od (or otherwise known as the HC60NG) for 10 secs, then turn back on. then hold the grey button in for 15 secs. release then hold in for a further 5 secs.
go to the honeywell cm61 press the off button. hold temp up. temp down and prog 1 in for 3 secs until the dipslay goes to INST. at this point release all 3 buttons then press the i button until a beacon starts flashing.
this is now the end to your problem.
N.B the reason the green light was on is because the man override button will have been pressed.
hope this helps
Posted on Feb 11, 2009
SOURCE: require room thermostat for ferroli combi boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Posted on Mar 12, 2009
  • 33 Answers
SOURCE: ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Posted on Jan 17, 2010
  • 1249 Answers
SOURCE: biasi boiler not heating house thermostat can be set on 80 house will not get warmer than 55
time for a more thorough troubleshoot. check to see that the boiler actually operates when commanded. check to see the circulation pump operates. maybe a valve is closed.
Posted on Feb 15, 2016
Biasi combi boiler with red light flashing at honeywell r6660d
Here is the biasi site that should have your manual. With no model number, I hope this helps.
Feb 15, 2014 | Honeywell Programmable Thermostat Heater
Diagram honeywell wireless room thermostat system boiler model r6660d
Honeywell web site will have all the information you need.
Jan 02, 2014 | Heating & Cooling
Biasi too hot
check pump is running ok..if not replace it the pump, if pump is ok then u will need to descale boiler put in system by rad or if not combi then put in open vent tank make shure its the small tank also make shure the valve in tank is not stuck
Oct 11, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
I have constant 24/7 humming noise (combi boiler i think) the boiler itself is not humming but seems to be in the pipes? mainly kitchen & upstairs, there is "hot spot" for the noise as you go...
If you turn the power off and it's still there then it's not anything electrical in the flat.. it could be transferred noise from another source. I would try locating the sound by listening through a tube to locate the sound more accurately. This method of sound source location is used by old fashioned mechanics listening for engine noises and is very good at finding them..
good luck !
Mar 30, 2017 | Water Heaters
Looking for a free manual for a Biasi boiler
Most Biasi boiler manuals can be found at www.qhtinc.com hope this helps
Dec 09, 2010 | Heating & Cooling
HOW TO WORK THE TIMER
I couldn't find the exact match for your boiler but I have included the website for you. Since you have the product right there, you will probably have better luck. If you can't find what you need, then use the contact info and give them a ring.
http://www.biasi.co.uk/frameset_acro.htm
Apr 07, 2009 | Water Heaters
Heating & Cooling Logo
24 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
