Question about Dream Maker Spas EZS-UHH-GG-F
Water leaking under spa under the motor but not part of the motor.
2 Suggested Answers
adamh294
  • 310 Answers
SOURCE: I received my brand new
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Posted on Jul 27, 2011
Testimonial: "Thanks so much! This helps me greatly. So glad I found this site. I will frequent often."
Have a dream master spa 8302 turned on nothing happens. The pump light is on
Is the motor on? Does it make any kind of noise(probably bad)? does it feel warm to the touch? Make sure there is water in the pump, loosen up a fitting near the motor WITH ELEC. OFF, check to see if water leaks out nothing gumming it up inside or anything. if water is flowing freely and it does one of the 2 things earlier (heat/noise) you should have the motor replaced. If neither of the 2 things earlier than probably some kind of electric problem or programming with the spa control.
Nov 16, 2015 | Pool & Spa
How to fix a hayward pool pump leaking from under neath
Shaft seal has failed. Replace it immediately or water will get into the motor and the motor will have to be replaced. The leaking is there by design to let you know when its time to replace the seal.
Aug 17, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
My hot tub was just refilled yesterday and now when the pump comes on the water level lowers. I don't see a leak anywhere
If you are just refilling your spa after having it empty for a time, your shaft seal on the pump motor has dried out and has shrunk making the seal leak. Soon it will drip water into the motor housing and the motor will seize. It is very easy to change a shaft seal. E-mail if you need help
adamh@newconceptchem.com
If you
Sep 19, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
My spa leaks water to just below the adjustable jet nozzles.
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
Dec 10, 2008 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas EZS-UHH-GG-F Logo
Top Dream Maker Spas Clothing Accessories Experts
Da Doc
ray gallant
Are you a Dream Maker Spas Clothing Accessory Expert? Answer questions, earn points and help others
