Question about Dell Computers & Internet
Why does my other computer make a buzzing noise and the screen dosn't show nothing
The screen is totally blank like it never came on but everything else on the computer looks like it's working but the moniter works on other computers
    Guru:
  • 377 Answers
You didn't mention about your PC spec. it will be easy for me to understand sinario
If your onboard graphics (upp slot..) the lower slot what im assuming your dedicated graphics card. With your dedicated graphics card installed the onboard does not work. Just re-instal the drivers for your dedicated card.
Posted on Feb 16, 2014
  • 383 Answers
SOURCE: Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Posted on Dec 20, 2007
SOURCE: Blinking Screen?
mine does the same thing... what is a EHT problem & how do I fix it??? thanks!
Posted on Mar 11, 2008
ginko
  • 19396 Answers
SOURCE: DEAD SCREEN
Disconnect completely computer and display form power cable for ten minutes, plug them back and restart ().This is called hard reset.
If you still have the problem try checking the display video cable, both in the monitor and computer socket.
If it still does not work connect PC to a different monitor, just to test that is not the pc or the video card the problem.
If it still does not work the blackout may have caused a short in your monitor or a system failure on pg then get back here and post the new problem.
regards
Posted on Mar 13, 2008
  • 1011 Answers
SOURCE: Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Posted on Aug 08, 2008
SOURCE: Monitor is black. Press power on monitor/screen shows for 1 sec
We have the same problem and think that the monitor may be getting too warm with staying on all of the time. Try to turn off the monitor when you arent using it. It might save you some time while you look for another monitor.
Posted on Dec 12, 2008
Reset does not work , screen blank ,responds to nothing.have tried just about everything , where can I send it for repair ,
Most probably the battery causing thr problem. Try to reset to factory settings and or format the unit. Sometimes there are issues with author rights and in that case You have to get the unit to a SONY technical service to clear its internal memory.
Oct 09, 2013 | Sony 8GB Walkman Video MP-3 Player With...
Green power light is on-screen remaining totally
defective unit, have it checked by repair center
Oct 19, 2009 | Computers & Internet
When start up the screen is blank, nothing happens
Press the F2 key several times to make sure that the screen brightness is up.
Put your ear down on the laptop on the zone left of the trackpad and below the keyboard and listen for the little whirring and clicking noises of the hard drive. If it is making noises, just walk away for at least 30 minutes and see what happens in that interval.
Look carefully at the screen in good light and make certain that here is no image on it. You could just have a bad backlight.
If so, you can connect the DVI port on the MacBook to a computer monitor or most flatscreen TVs and regain access to the screen until you get the backlight repaired.
You might try that regardless. Even if your display is totally inoperative, the DVI port may still function.
If the drive has stopped making noise and the screen is totally blank, 1. Try starting up the MacBook with the DVD that came with it, and if that doesn't yield anything, 2. Take the MacBook to the Apple Store and ask for a Genius appointment.
Oct 16, 2009 | Apple Computers & Internet
We went to use our Toshiba L305D laptop. All lights are lit, but nothing shows on screen. Hold in power button to restart and computer sounds like it's rebooting. Screen is totally blank.
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
Jun 25, 2009 | Toshiba Satellite L305D-S5904 Laptop
2001 BMW 530I
I would recomend looking behind the left access cover in the trunk where the navigation computer is located. Inspect the area for any water intrusion, and if possible check the connections to the navigation computer for water or corrossion. the display colors are generated by the navigation computer via RGB lines. If the nav computer is cutting out, that would explain why a battery reset helps restore the picture.
Mar 25, 2009 | 2001 BMW 5 Series
Monitor is blank/dimension 2400
If you put a spare monitor on your computer and everything is fine I'd say it has an electronic problem. If the screen is still blank I would look at the video card or PC itself as the problem. Just for fun check the video cable for bent or missing pins.
Mar 23, 2009 | Computers & Internet
Blank screen
Hi!
A simple test is to connect another working monitor, to figure out if the problem is at cable connection or at graphics card 's output, and replace properly.
good luck!
Dec 26, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
Alun Cox
