Question about Miele Dryers
It shuts Off and i need to open the door and close it. Then press start and it Will run for a couple of minutes and then Its the same...
hotuna
  • 288 Answers
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Posted on Dec 23, 2007
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 70 Series Gas Dryer doesn't shut off
replace timer
Posted on Dec 28, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
  • 686 Answers
SOURCE: wont keep running.have to open door to restart every minute or so
YOU MIGHT HAVE A BAD DOOR SWITCH OR A BAD CYCLING THERMOSTAT OR THERMAL FUSES ON THE BRINK. DO THIS GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PARTS 2986 CHECK THI PART FOR CONTINUITY. THEN LOOK FOR THESE 2651 AND CHECK TO SEE IF THEY FUNCTION BY TAKING THEM OUT AND APPLYING A LIGHTER TO THE SENSING SIDE YOU SHOULD BE ABLE TO HEAR AND FEEL THEM CLICK. IF THEY DO THEY ARE GOOD. THEN LOOK FOR 898078 IF YOU HAVE IT OR 904589 EITHER A THERMOSTAT OR DOOR SWITCH IS BAD. GOOD LUCK
Posted on Apr 17, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Fault code f26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Jul 30, 2011 | Maytag Washing Machines
Automatic side door will not operate 2000 sienna LE. No noises when door button is pressed on dash or remote
this problem can only be diagnos bya a dealer specific scan tool, so they can go into a body computer and run a check, there a presure sensitive switches, but before you going into any dealer make sure all seals are clean of soda, coffe or any spills, also at point of contact with body,
One more thing hope this will help you: close all doors unlocked and remove your negative cable from battery, live it off couple minutes....reconec then turn on power door swith and press open door switch and hold it until door opens completly, then press to close it and hold switch until door is completly close, reset done Good Luck hope this help,
Feb 12, 2011 | 2000 Toyota Sienna
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
20 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
