Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven burner won't stay lit goes out
The oven burner won't stay lit when it is heating up or maintaining heat. When I take the inside bottom cover off of the oven I can see the long tube burner is lit. Then it will fade like the gas is not flowing fast enough till the fire is out. Then there is a slight gas smell and it comes back on. When it relights there is a sound of gas igniting like starting an outdoor gas grill. A woof sound this happens every 30 seconds or so. The oven still works but it takes a while to get up to the correct temp. I have checked the gas line to see if there is a kink stopping the gas flow. I can also verify that the ignitor stays orange and glowing.
    New Friend:
  • 19 Answers
A make or model....?
Posted on Apr 07, 2017
  • 833 Answers
SOURCE: GE XL44 Oven - On/Off heating of bottom burner.
Mag...not sure here. Is there a particular reason that you're suspecting a problem? Does the unit heat much slower than before? Does it bake properly? You may be looking for problems that aren't.
Posted on Dec 13, 2007
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
  • 23 Answers
SOURCE: igniter is fine. oven won't heat . broiler fine
Maybe the wholes are plugged with food or residue not allowing the gas to flow. Unplug it with a paperclip. Even though the ignitor looks fine it may not be giving enough amps to light the second and subsequent times. Ignitors are farely cheap for this model and if ur technical can do it urself. All that is required is screw driver, igniter, wire cutters (strippers), and two PORCELAIN wire connectors. Good luck.
Posted on Sep 04, 2009
  • 3361 Answers
SOURCE: GE Profile gas range - Model Number removed by
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Posted on Jan 03, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from
Jan 04, 2016 | Ovens
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
My Tappan gas oven will heat up to temperature when first started but will not maintain temperature after that. The burner will not re-ignite. If I lower the temperature to the off position then put back...
thermo couple may be defective. Disconnect oven, look inside oven it will be a 2-4 inch tube looking brass type metal. use ohm meter check continuity if non then most likely its defective. other then that it may be the control board.
Sep 11, 2017 | Tappan Kitchen Range
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 10, 2010 | Dryers
One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Feb 23, 2010 | Vulcan Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My gas oven stays warm even though it is turned off
    A standing pilot such as this will give off heat. So long as the gas bake burner is not lit also, you will be fine. If the bake burner IS lit you have a defective oven control.
    Jun 26, 2009 | GE Ovens
    Slow heating- low gas to burner
    The main solution of it is to clean the gas tube.
    May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
    Oven is not heating properly
    Could you find the completer mode number because the number listed above your post is for a gas oven.
    Look at following areas for the model number
    • Under Right Front Burner
    • Under Left Top Burner Front Or Rear
    • Under Main Top Left, Rear Or Center Front
    • Under Left Rear Or Right Front Element
    • On Nameplate Inside Burner Box
    • On Front On Burner Box Bottom
    • On Nameplate On Oven Door Liner
    • On Main Front Behind Oven Or Compartment Door
    • On Front, Center Bottom Of Burner Box
    • On Thermostat Cover Under Main Top
    • Thank You, Sea Breeze
    Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
    Dec 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    73 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
