Question about Phoenix Gold Tantrum 1200.1 Car Audio Amplifier
My speaker wire is putting off a arch and frying my subs what is cause this to happen?
My speaker wire to my subs are arching making a really big spark and I fried two 12s and I don't know why can anyone help
    Problem Solver:
  • 15 Answers
What size cables are you using to connect your sub to the amp?
Posted on Feb 18, 2014
Need daigram
By chance do the front panel lights flicker and "frying" sound comes from speakers when you turn the amp on? If so replace the OFF/ON wafer switch as the contacts are arching when they make contact.
May 10, 2014 | Sony Audio Players & Recorders
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
Instruction for setup of American Camper tent 8x11
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
Everytime i turn on my stove it makes a big bang noise, i cant figure out what else it could be.
Sounds like your cord or wireing may be arching. Your elements may also be making that noise. Carefully try to see if you can see what is arching.
If you need further assistance please comment me back.
Jul 27, 2011 | Ovens
Just bought new balance wr 859, having pain of top of foot (where bump is) seemingly from the tight lace, however when loosen the lace, sneaker is too big. thank you ege972@aol.com
Have you considered tongue pads? They are soft cushions with felt on one side and adhesive on the other that you can stick to the tongue of your shoes to provide cushioning and reduce slippage & pressure from laces on your instep.
Some options are available on the site below.
http://www.feetrelief.com/feetrelief/arch_support_accessories.htm
http://www.wardrobesupplies.com/store/m2_footcushion.html
One thing you might want to consider is if you have a high arch to your foot. Generally, the higher the arch, the higher the instep which will effect the way shoes fit you. The shoe that fits comfortably over your instep without causing pressure may then be too loose around the heel. Runners with high arches also experience more foot pain/strain because their feet actually fall harder than a lower arched runners. You may want to consider the Nike Pegasus or Adidas Cushion if you think this is the case.
I really hope this helps you.
Nov 17, 2010 | New Balance WR859 Running Shoe Powder 13 D...
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
Jul 12, 2010 | MSR Family Tents
1967 chevy ignation problems
Make sure it didn't burn the contacts of the ignition switch.
Of course you will want to check the main fuses as well. Fusible links if it has them.
Mar 20, 2010 | 1989 GMC Sierra
There is a arch at the bottom going to the left
Covergence needs to be fixed replace Both of your ICs they are big black ICs with STK on them for example STK392-110 if this the # on yours use 180s better ics.For parts Call 1-800-223-3205 www.electronix.com.
Dec 26, 2008 | Toshiba 57H82 57" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Phoenix Gold Tantrum 1200.1 Car Audio Amplifier Logo
41 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
