Question about DonJoy Legend SE-4 Knee Brace - PCL Knee Brace - Right - Large
Donjoy legend se-4 knee brace locks on one side
Knee hurts
Mine to. Since I was in Junior high.
Oct 20, 2016 | Cars & Trucks
Where can I find a brace for moderate stability of a ligament?
I would recommend the DonJoy Deluxe Hinged Knee Brace. You can find it for $119.99 on http://www.betterbraces.com
Apr 22, 2013 | Health & Beauty
What kind of injuries can knee braces be good for?
Knee braces can be useful as a prevention against or rehabilitation for; ligament injuries, torn cartilage, tendonitis and arthritis.
Jan 15, 2013 | Health & Beauty
What is a Prophylactic Knee Brace?
Prophylactic Knee Braces are used as a way of preventing knee injuries. Alot of athletes use them to help minimize the risk of sports-related injuries.
Where is the interior fuse box for 1993 acura legend?
bottom left of the driver side floor. should have a turning thing on it cant miss it have to get out of car and on your knees to see it
Nov 30, 2010 | 1993 Acura Legend
How can I remove an altenator from a 98 ford contour se 2.5 l motor. And what are any suggestions?
Fig. Fig. 5: Alternator mounting-2.5L engine
  1. Disconnect the negative battery cable.
  2. Release the drive belt tensioner and remove the drive belt from around the alternator.
  3. Raise and support the vehicle.
  4. Remove the passenger side front wheel and fender well splash guard.
  5. Disconnect the passenger side outer tie rod end from the spindle. See .
  6. Remove the exhaust system Y-pipe.
  7. Unplug the connectors and remove the cables from the alternator.
  8. Remove the alternator brace retaining bolts and the brace from the vehicle.
  9. Remove the passenger side halfshaft. See .
  10. Remove the alternator mounting bolts and remove the alternator from the passenger side fenderwell.
To install:
  1. Install the alternator on the bracket and tighten the mounting bolts to 29-40 ft. lbs. (40-55 Nm).
  2. Install the passenger side halfshaft. See .
  3. Install the alternator brace and tighten the retaining bolts to 15-22 ft. lbs. (20-30 Nm).
  4. Install the alternator connectors and the cables. Tighten the terminal nut to 80-97 inch lbs. (9-11 Nm).
  5. Install the exhaust system Y-pipe.
  6. Install the passenger side outer tie rod end to the spindle.See .
  7. Install the passenger side fender well splash guard and front wheel.
  8. Lower the vehicle.
  9. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
  10. Connect the negative battery cable.
Mar 15, 2010 | 1998 Ford Contour
Location for the head light control module
The LCM or lighting control module is located under the dash to the right of the steering wheel, first you need to remove the hush panel under the knee brace, then there are 2 screws the hold it to a bracket. Unplug the 4 connectors towards the back and then slide it out and replace.
Oct 22, 2009 | 1996 Lincoln Town Car
DonJoy Legend SE-4 Knee Brace - PCL Knee Brace - Right - Large Logo
116 people viewed this question
Top DonJoy Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DonJoy Health and Beauty Expert? Answer questions, earn points and help others
