Question about GE Profile Spacemaker Over-the-Range Microwave
Some buttons on the microwave work and some don't
An above the stove. There was a light in the nearby outlet which I reset.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Need new keypad
Posted on Sep 23, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Posted on Nov 25, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: lights and fan not working on over the stove microwave
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 16, 2008
kel1guy2002
  • 3740 Answers
SOURCE: stove fire smoke on microwave above stove.what
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Posted on Mar 16, 2010
  • 906 Answers
SOURCE: Microwave stopped working. Everything else is functioning.
good day,
hope this link below will solve your problem.
microwave ovens
Posted on Jul 31, 2010
SOURCE: Hi! I have a GE XL1800
you may go to www.ge.com and call their phone support to replace that unit...
Posted on Dec 28, 2010
My microwave is not heating
Are you sure you have power at the outlet? If not check your circut breaker box. You may have a GFI circut. The GFI outlets are very sensitive. They have reset button and test button. If other "non GFI" outlets are on the same cirute they are affected by the GFI outlet. The GFI outlets do fail at times, and need to be replaced. Have you had recent power outage? Sometimes our "smart devices" are too smart.
If you have power, I'd unplug for a few hours and see if that might reset it's "brain" If that doesn't help you may have a panel problem. Owner's manual? Check troubleshooting section. Warranty?, pursue that. Age of microwave? Consider the cost of repair vs. finding a lightly used "working" microwave.
Mar 03, 2015 | Microwave Ovens
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
I Have a GE Spacemaker over the stove microwave. I think it is 1000 watts. It's 7 years old. Everything works but it doesn't heat anything. There is 23 volts going to the fan unit in the...
HELLO.
Since there is an amount of volts from the outlet, the fault is from the microwave breaker.
The solution is given below.
Reset the microwave breaker.
Take the back cover of the microwave off with a screwdriver.
Inside you will find a motor.
Most microwave motors have a small red reset button on them. Hit that button.
Your microwave should work again if the breaker was the issue.
Thanks
Sep 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Screen does not respond to touch
Does it beep when you push the buttons?
If it doesn't, your touchpad may be bad so you're unable to communicate with the unit's computer.
Mar 17, 2008 | Microwave Ovens
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
