Question about Samsung SyncMaster S22B150N - LED monitor - 21.5""
New monitor no sound
Monitor is working there is no sound do we need to add speakers
    Top Expert:
  • Samsung Master
  • 8,302 Answers
Not all monitors come with sound built in,so yes try adding speakers.
Posted on Apr 01, 2015
I purchased a new Dell 23" monitor and it has no sound? Do I need a sound board? My old monitor worked very well!
you might just need a mini-jack to mini-jack cable to connect your sound device on your pc to your new monitor. Remember that it is not all monitors that feature speakers.
Apr 02, 2011 | Computers & Internet
The speakers are intergrated in to the monitor and don't seem t.
First, find out if the speakers or audio is working properly. At your PC menu, left click Setting, Control
Panel, and Add hardware. Click the add hardware wizard and just follow the instruction until you will find all the installed hardware of your PC. Click at the Audio, and the sound driver of your PC to find if these are working properly. Assuming that this are working
properly, test the audio output of your PC by putting
in another set of speaker (borrowed or otherwise).
If you hear the sound, then it is a connection problem. The wire to the speaker could be broken, or
the speaker itself. Under this condition, it is your
option to open up your monitor and test the speakers.
Or to just buy a new set of speakers. Unless you
are familiar with handling an open monitor, you may
go ahead with opening the monitor Otherwise, it is
wiser to buy the speakers which is much cheaper
than a monitor that could accidentally get damage.
Nov 29, 2009 | NEC Speaker Wire Computer Speakers
No sound from monitor
Try to re-install your audio driver !! Also go to add and remove and remove media player and then go and re-install windows media player again( probably a newer version ) should work!!! swampratt200 AAAEEE!!!!!
Jul 21, 2009 | HP Compaq WF1907 Monitor
No audio output device is installed, how do I put it in?? MAG monitor, Compace tower..
Depends on what operating system you are using. If you are using Windows Xp and above. You can try going into add remove hardware. Try adding a new hardware from list. When you can try reinstalling the windows audio driver. This has worked for me numerous times. Try this step
My computer
-Control panel ( use classic veiw)
-- Add Hardware
--- Click Yes
---- Scroll down to the bottom of the list and select add a new hardware device
----- install from a list 2nd option
------ click on sound video and game controllers
------- Try the Aztech systems and use the first option on the right hand window.
then click next until you are able to install it. It should work after that.
Best of Luck
May 28, 2009 | Audio Players & Recorders
How do you make the sound work ? Hannspree Monitor HF237
When you have a monitor that has built-in speakers, you must hook that monitor to your computer with a cable--the type of sound cable any other speakers have. It has a male jack on each end. One end goes into the little sound in hole in the back of the monitor. The other goes into the green hole on your sound card (either the built-in card or an add-on card).
Another thing to check is to see that the sound drivers are working. You know they are if the computer had sound that played through other speakers. If you hook it all up and there is no sound, then you most likely have a sound driver problem (or your sound is muted!)
If this explanation helps, be sure to rate the answer, please.
Mar 30, 2009 | Computers & Internet
Have a dell flat panel pc monitor, want sound. the only thing i see is speaker power?? whats this for?
the monitor has the ability to attach a sound bar (AX510) the power connection is for the add on speakers
Jan 28, 2009 | Dell E173FP 17" LCD Monitor
Trying to add speakers
The only way i can see of feeding two sets of speakers from the one pc would be to buy or make up a "splitter" audio lead .....i.e a 3.5mm stereo jack on one end connected to the pc with two lots of wiring going to 2 3.5 mm jacks. I don't know whether a store like Maplins would sell such a lead. Are you any good with a soldering iron??
Dec 31, 2008 | Gateway GT5468 Desktop PC
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Feb 25, 2008 | Gateway Essential 500 PC Desktop
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
Samsung SyncMaster S22B150N - LED monitor - 21.5"" Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
