Question about Hotpoint Washing Machines
I have a 1988-1989 Hotpoint WLW3500B. The agitator doesn't go back & forth and makes a humming sound. When empty the agitator spins freely both ways by hand.
I have a 1988-1989 Hotpoint WLW3500B. The agitator doesn't go back & forth and makes a humming sound. When empty the agitator spins freely both ways by hand. Before when turning by hand it used to not spin freely.
  • 126 Answers
SOURCE: Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Posted on Jan 12, 2008
  • 6 Answers
SOURCE: series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Posted on Jan 14, 2008
  • 71 Answers
SOURCE: kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Posted on Dec 12, 2008
Bfsas1
  • 258 Answers
SOURCE: agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Posted on Jun 29, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Hotpoint washer spins but does not agitate
CHECK THE WATER PRESSURE SWITCH AND THE DOOR SWITCH, ANOTHER THING TO CHECK THE CAM DOGS INSIDE THE AGITATOR? CAN U TURN THE AGITATOR INSIDE DRUM MANUALLY AND SEE IF IT ENGAGES THE DRUM, TURN IT BACK AND FORTH AND IT SHOULD LOCK AND GRAB THE TUB?
Sep 02, 2014 | Hotpoint Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My washer fills with water,wont agitate but spins and drains
The agitate is a slow speed on a two speed motor. That said, there are several things
which can cause this. I have seen a bad connection on a motor plug do this.
This can often be seen as a dark spot on the semi- clear connectors.
Also a missing point on the timer (They can burn shut and pull off the contact). One way
to test the timer is to see if the washer will agitate on other cycle settings.
Third would be the motor itself. I haven't seen a partial failure ever.
One last thought, If you have a two piece agitator, the "Dog Agits" may be bad,
If you can grab the upper portion of the agitator and it turns freely back an forth, then
they have worn out. They are about 4 dollars. Take off the top plug/softener cap and there is a
bolt (usually 7/16th) that unscrews. Loosen this bolt counter clockwise and remove upper
assembly, The center part containing the agits can be removed and should be very
obvious as to their reassembly. Hope this helps.
Mar 10, 2011 | GE WDSR2080D Top Load Washer
Not agitating
Thanks for writing to Fixya.com.
This is sounds like the little gear checks under the agitating cap , take a screw driver and pop the cap on the top of the agitator, and look at the 3 little plastic, catches, there is a gear there where it goes back and forth , and when it turns, these little catches, connect, and make the agitator spin. If it has a belt system then please make a note of the belt.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Apr 07, 2010 | Hotpoint VBXR1090B Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
