Generator with Integral Rear Mount Voltage Regulator, Internal Fan Type
With the key in the RUN position, voltage is applied through the charge indicator lamp I circuit to the voltage regulator. This turns the voltage regulator on, allowing current to flow from the battery sense A circuit to the generator field coil. When the engine (6007) is started, the generator (GEN) (10346) begins to generate alternating (AC) current which is converted to direct (DC) current by the rectifier internal to the generator. This current is then supplied to the vehicle's electrical system through the battery positive voltage (B+) terminal located on the rear of the generator.
Once the generator begins generating current, a voltage signal is taken from the stator and fed back to the voltage regulator S circuit, turning off the charge indicator/lamp.
With the system functioning normally, the generator output current is determined by the voltage at the A circuit. This voltage is compared to a set voltage internal to the voltage regulator, and the voltage regulator controls the generator field current to maintain proper generator output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit (battery sense voltage). The A circuit voltage is compared to a set voltage internal to the voltage regulator, which controls the generator field current to maintain proper output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge in the winter and reducing the chance of overcharging the battery in the summer.
A fuse link is included in the charging system wiring on all vehicles. The fuse link is used to prevent damage to the wiring harness and generator if the wiring harness should become grounded, or if a booster battery with the wrong polarity is connected to the charging system.
Mitsubishi 215-Ampere Generator
The Mitsubishi 215-ampere generator is an internally regulated, brushless unit that is self-current limiting and temperature compensating. The regulator is integral with the generator and the fan is external.
VISUAL INSPECTION CHART
Mechanical
Electrical
- Before attempting to test a battery, it is important to give it a thorough examination to determine if it has been damaged.
- Batteries are tested to determine the state of charge and ability to crank an engine. The result of these tests is to show that the battery is either good, needs recharging, or must be replaced.
- Preliminary checks to the charging system should be made regardless of the fault condition. These checks include:
- Check the fuses/fuse links to the generator to ensure that they are not burned or damaged. This condition, resulting in an open circuit or high resistance, can cause erratic or intermittent charging system concerns.
- Check battery posts and cable terminals for clean and tight connections. Clean the posts and the cables to ensure good electrical contact.
- Check for secure connections at the generator output, voltage regulator and engine ground. Also check the connection at the power distribution point.
- Check the generator drive belt to ensure proper tension and no slip between the generator pulley and the drive belt. Refer to Section 03-05 in the Powertrain, Drivetrain Manual.
- Check battery for full charge.
- Before performing charging system tests on the vehicle, note conditions such as: slow cranking, discharged battery, charge indicator lamp stays on with engine running, charge indicator lamp does not illuminate with ignition switch in RUN and engine not running, etc. This information will aid in isolating the part of the system causing the symptom.
- When a relatively new battery is discharged, test for current drain. The following are some of the most common current drain concerns:
- Glove compartment lamp stays on with the door closed.
- Engine compartment lamp stays on constantly.
- License plate lamp or interior lamp stays on constantly.
- Other electronic component concerns.
