Question about Performance Teknique ICBM-9500T 7" In-Dash Fully Motorized TFT Monitor DVD Player w/ Built-In TV Tun... Car Video Player
Blue tooth issues
Performance technique ICBM5256 when using the blue tooth to make and receive phone calls you can hear the other person but they cant hear you. Whats up?
How can I fix my blue-tooth so the other person calling can hear me?
Sounds like a setting issue, i.e. you have your blue-tooth on mute. Check the instruction manual and turn mute off!
Oct 17, 2015 | Plantronics Black Marque M155 Wireless...
2-way communication failing. Please help!
try and use it with a hands free set or a blue tooth.. if that works contact www.phoenixtec.ca the can help you
Jul 10, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I got a avic z110bt and when i connect my blue tooth to my phone i can be heard but i cant hear who on the line i have reset the unit and i updated the unit
You must adjust the volume on your phone; make a connection with some one using the blue tooth and then try to raise the volume on your phone and also on the car stereo and you'll hear the other person. hope this resolve your problem.
Dec 21, 2010 | Pioneer AVIC-Z1 Car DVD Player
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 | Cell Phones
I can not hear the caller and the caller can not hear me
click on the blue tooth icon in your tools menu.
delete unwanted connections and switch offf the option. restart phone
Dec 17, 2008 | Nokia N73 Cellular Phone
Blue tooth
well it may not be the phone it could be the BT Headsets you should tRY ANOTHER one.....also you can do a reflash of the firmware as well
Sep 01, 2008 | Samsung SCH-u740 Cellular Phone
Jabra 250v blue tooth headset
please mail me service center in india particular in thane mubai with phone no. my emain chalke_pravin @sify.com
Jan 22, 2008 | Jabra BT250 Consumer Headset
Car Audio & Video Logo
19 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
