Question about LG LRE30453 (Electric) Range
Lg 30453 cooktop works only sometimes
Hi, i have intermittent issues with the burners of my tenant lre30453st/01. Sometimes come on, sometimes not. sometimes come in and shutoff midway through cooking. how do i test the surface contol board for voltage. how much voltage am i looking for. ive read alot about removing the top back panel and reseating/cleaning the two blue ribbon connectors. jeremias , February 15, 2014 Any help biker dave would be much appreciated. i have the part in my cart but not sure if that the surface control board is the issue. If it was, wouldnt it just work or not work?
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
  • 161 Answers
SOURCE: LG Range Touchpad Not Working
The touch mebrane is faulty and needs to be replaced.
Posted on Jan 22, 2010
SOURCE: burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Posted on Nov 03, 2010
richroth
  • 9472 Answers
SOURCE: Heat Error F7- unplugged over
Here is the service manual for you oven. There was to much information to post here so look at page 6-5 to 6-7 for checking the oven components. Some of the testing may require a test meter.
Happy Holidays The FixYa Team
Posted on Dec 18, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: The burners on my LG LRE30755ST range will not
Sorry to read about your problem, I hope this helps you out.
The PF message will appear whenever there has been a power interruption to the appliance. To clear the PF message touch CLEAR/OFF control pad and be sure to reset the clock with the correct time of day.
• To clear the HS message touch ON/OFF pad.
if this does not correct the problem. you then have a defective control card, inside the range.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
What causes my stove top to randomly beat approx 8 times in a row every 2 minutes for sometimes up to several hours, sometimes a few minutes, sometimes quite all day?
If you mean 'randomly HEAT', then I would suspect the control panel. There would be logic to detect the control touch and convert that into a signal to the controlling system that applies power. If the touch panel is faulty, it may signal for power intermittently.
Oct 27, 2014 | LG LCE3681ST Stainless Steel 36" Radiant...
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Mar 27, 2013 | LG Ranges LRE30453ST 30 Inch Freestanding...
Even after the burners are lit they keep on trying to ignite, sometimes all four will be clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 31, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
I am experiencing some problem with the controls on the cooktop. When turning the dial to the desired temp, sometimes the burner comes on, sometimes it does not. Some of the burners only engage when we...
I haven't heard of this problem before. If you do press down and the hotplate starts to work we know that the hotplates are okay. The only thing this could be is an internal problem inside the hotplate controller, possibly with the contacts. The controllers will need replacing.
Mar 04, 2011 | Whirlpool GJC3034 Electric Cooktop
LG LRE30453 (Electric) Range Problem is front left burner is shut off but the burner remains hot ... Range won't stop beeping. ...
I have a lg electric dual convection range (Model # lre30757st) and the front left burner turns on and off on its own. (It will not remain off.)
Jul 15, 2010 | LG LRE30453ST (Electric) Stainless Steel...
Radiant cooktop stays on at low settings. fix?
it is the burner switch that needs to be replaced.the thermocouple function is built in the switch.
Aug 17, 2009 | Cooktops
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
http://producthelp.whirlpool.com/Cooking/Cooktops/Cooktop_Product_Assistance/Cause_of_gas_burners_not_igniting%2C_lighting%2C_clicking_or_ticking
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Jun 02, 2017 | Whirlpool 30 in.GLT3057 Gas Cooktop
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Intermittent fault
i wold pull the orfice out of the burner and check for a partial obstruction hold it up to the light look down in the burner tube
Jan 25, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
LG LRE30453 (Electric) Range Logo
19 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
