Question about Canon PowerShot Cameras
Can't zoom in or out, can't delete pictures
Can't zoom in or out. I can't delete pictures
PICTURES GOT DELETED
Don't panic! You can recover all deleted pictures from your camera with the help of a good photo recovery tool. Launch Remo Recover on your laptop, connect your camera and get back deleted photos.
Dec 27, 2013 | Kodak Easyshare M531 14mp 3x Optical/5x...
How do I delete pictures from my EasyShare CD82?
While viewing the picture to be deleted, press the trashcan button (located just below the zoom rocker). If you want to delete all the pictures on your memory card, format it.
Oct 28, 2012 | Kodak Easyshare CD82 Digital Camera
How do I delete a still photo I took and don't want?
In PLAY mode press down-arrow. Use left/right arrows to scroll through the pictures and display the one you want to delete. Use up/down to select "Delete." Press SET to delete the picture. Repeat as necessary. Press MENU to exit.
Aug 17, 2010 | Casio EXILIM ZOOM EX-Z850 Digital Camera
How to delete pictures from samsung L200
To delete a single image, select the image in view mode by pressing left/right buttons, then press delete button (little garbage can symbol). To delete more than one image go through images and press T button (zoom button) for each image you want to delete to mark them for deletion, then press ok to delete the selected images. If you want to delete all images, just format the card. Hope that helps
Jul 24, 2010 | Samsung L200 Digital Camera
I can't delete more than 1 picture at a time, how can I do this ?
You can try this.
If you are watching your pictures, press zoom out button, then try to delete. Maybe camera let you to choose pictures.
Aug 10, 2009 | Pentax Optio 50 Digital Camera
How can i delete pictures on my digital camera
Push the delete button or the little picture of a trash can. You must make sure the picture is unlocked. Your memory card has a little switch. Make sure it is set to unlocked. (not on locked)
Mar 19, 2009 | Olympus D-400 Zoom Digital Camera
Deleting pics
When in the playback menu, toggle the zoom out, as if you had already zoomed in on an object and then wanted to zoom back out. This should cause the pictures on your camera to be displayed in thumbnail mode. When you hit the trash/delete button in this viewing mode, you will be given the option to delete the entire folder's contents. You can also highlight a selection of thumbnails, then delete them all at once by choosing the "Select" option.
Nov 17, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Deleting Pics.
IF YOU HAVE A MEMORY CARD, YOU CAN DELETE IT THROUGH YOUR COMPUTER OR YOU CAN CONNECT YOUR CAMERA TO THE COMPUTER AND DELETE THEM FROM THERE.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Instruction in manuel nor very clear hard to understand
ok to Delete a picture when your looking at the picture click the center button then a bar comes across the bottom. the first one on the bar is Delete, click center again then to delete ONE click down to delete ALL click up. same with videos. and to zoom in there are 2 buttons joins with T & W on them. T is zoom in and W is zoom out :D
Dec 30, 2007 | Jazz DV-179 Digital Camera
Cameras Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
