Question about Kenmore 24032\24036 Top Load Washer
Washer that matches kenmore dryer model # 110 625 12 101
Won't spin makes a dragging noise
  • 236 Answers
SOURCE: Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Posted on Jan 20, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
  • 38 Answers
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Posted on Mar 08, 2009
  • 1937 Answers
SOURCE: kenmore 80 series washer is making a noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.
Posted on Jan 26, 2010
Testimonial: "Thanks, this was helpful. Unfortunately, we couldn't locate any broken parts. "
Kenmore stack top loading washer and dryer
kenmore washer won spin YouTube
Kenmore is sold by sears so go to
Enter your model number to get user manual, parts diagrams parts lists and order parts.
Model numbers are usually covered by the lid or door.
Oct 01, 2014 | Washing Machines
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis top load washer model 100 27072603 makes loud noise when it is spinning to dry. Sounds like bad bearing?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Kenmore Washing Machines
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore Dryer
ck rear support rollers and front if it has them may be out of round
Jul 23, 2008 | Kenmore 63942 Dryer
Kenmore Washer
check the coupler its between the motor and the transmission
Mar 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Jan 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
