Question about I-BEAD 200 (128 MB) MP3 Player
Format i-bead 150 - I-BEAD 200 (128 MB) MP3 Player
How do I get a bad smell out of plastic beads?
naturally, plastic beads has a bad smell. But, you may also try to soak that on a water with soap :) hope this helps
Dec 07, 2012 | Refrigerators
Change rear tire on john deere lawn tractor lt-150
i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
Apr 16, 2012 | John Deere Garden
Hi my name is Nick I have 1 question. Suppose a bead maker wants to separate 10,000,000 beads into boxes. She will put 100,000 beads into a box. Into which box would she put the 4,358,216th bead?
If the bead maker is putting 100,000 beads into each box, then it will take her 10 boxes to package 1,000,000 beads. To package 4,000,000 beads (which is 4 times as much as 1,000,000), she will need 40 boxes. An additional 3 boxes (we're now up to 43 boxes) will allow her to separate a total 4,300,000 beads. Bead number 4,358,216 is between bead 4,300,000 (requiring 43 boxes) and 4,400,000, and she will need another box to package those beads, so we can deduce that bead 4,358,216 will be placed in box number 44.
If you found this solution helpful, please leave a positive rating!
Aug 29, 2011 | Computers & Internet
Swimline unibeaded liner - Is this the same as a beaded liner
Beaded and Uni-bead are not the same.
A uni-bead liner is what is often called a J-hook, if you want to use it in a pool that uses a beaded liner you need to remove the bead receiver. A J-hook liner attaches right to the pool wall, not a bead receiver.
Mar 07, 2009 | Swimline 12 X 18ft Oval Beaded Caribbean...
My I-bead mp3 was formatted accidentally...
Your songs are most likely gone, formatting erases all of the data on the player.
Always back up your data on a seperate disk. Good luck.
Mar 08, 2008 | Electronics - Others
Not able to play all songs
some songs may not be in correct format
also, could require a firmware upgrade:
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Mar 29, 2007 | Transcend T.sonic 610 MP3 Player
I-BEAD 200 (128 MB) MP3 Player Logo
53 people viewed this question
Top I-BEAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an I-BEAD Audio Player and Recorder Expert? Answer questions, earn points and help others
