Question about Yamaha 2006 VK Professional
Where do you add gear oil on a 2006 yamaha vk pro
    Problem Solver:
  • 18 Answers
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Posted on Oct 12, 2014
Do I add oil to the gas in our Yamaha rhino 660 year 2006
NO - Karen
from the specs below this engine is a 4 stroke engine you may wish to run it on a higher octane fuel but that is your choice
but no oil as it is not a two stroke engine .
http://www.atv.com/specs/yamaha/utility-utv/2006/rhino/660-auto-4x4/detail.html
Apr 23, 2018 | Yamaha Motorcycles
Gear oil leaking from under the bike
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Re Belt drive gear oil leak Road Star Forum Yamaha Road Star
Oil leak gear oil
http://www.rswarriordocs.com/manuals/WarriorServiceManual-WO3646.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2006/LIT-11626-19-45_Road_Star_1266.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 16, 2014 | Yamaha Road Star Motorcycles
Gear oil leaking from under the bike on the side where the drive belt
Re Oil Seal behind pulley replacement Road Star Forum Yamaha Road Star
Oil leak behind drive pulley
Apr 16, 2014 | 2006 Yamaha Road Star
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
Mar 15, 2014 | Yamaha 2006 VK Professional
How to adjust gear chain on Yamaha VK pro
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
Dec 29, 2013 | Yamaha 2006 VK Professional
Rear wheel hub fluid
Pro honda hypoid gear oil,the dealer will give you the correct weight. 30 weight is what most use
May 27, 2010 | 2006 Yamaha V Star 1100 Custom
2006 R6 Shifting Problem
Howdy: The 3rd and 4th gears are used the most, after awhile the dog and shifting forks get worn more. Try changing to Yamaha Lube simi-syn oil 10/40. Drain oil after warm up (get trans oil warm). The oil is in a silver 4gal containe at the Yamaha dealer. This oil has helped me.
Good luck - Doug
Dec 09, 2009 | 2006 Yamaha YZF-R6
Where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
Apr 25, 2009 | 2006 Yamaha V Star 1100 Classic
Yamaha 2006 VK Professional Logo
383 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Gene Tuck
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
