Question about Kohler Flipside K-15996-CP Polished Chrome 01 Showerhead
Clogged with mineral residue
Normal monthly cleaning will no longer clean my showerhead. The water comes out of two of the choices of my Flipside. What can I use that won't harm it?
  • 2,760 Answers
Water borne calcium is most likely your culprit , im afraid that soap isn't gonna help you much on dissolving this and nitric acid will hurt the chrome and your skin/bones (nitric acid dissolves calcium) , replacement is best here , of course the best way is to prevent the minerals from ever getting to your shower in the first place by installing a water filter/softener combo on your main water line , it will help you save on soap too as less soap will be required to get same level of cleaning , ck your local yellow pages for a softener dealer in your area , most will come and test your homes water for free to determine your filtering needs
Posted on Oct 14, 2015
Checking to see if the water line is clogged or broken on my cuisinart dcc1200 coffee maker. The water doesn't come out of the showerhead. Help!!
Most likely clogged with a calcium buildup. Run a solution of water and vinegar through the machine to dissolve the hardness buildup. Stop about 1/2 the way through and let it set for an hour. Turn back on and let it finish. Remember to run a pot of clean water through after to wash out the vinegar. (You may have to run more than one clean cycle if it's really clogged).
Aug 31, 2016 | Cuisinart Coffee Makers & Espresso...
Can spring water be used instead of distilled?
The reason that distilled water is suggested it is the mineral deposits that are in the water.
Any other kind of water than distilled has more, and possibly a lot more minerals than distilled.
That means, it might depend on how soon you can no longer use your iron, as it is clogged with mineral deposits.
How much minerals are in the spring water is anybody's guess, some more, some less.
God bless your efforts.
Apr 07, 2016 | Irons
Machine is clogged and water will not drip through to make espresso. the steam frother works sort of
Did your User Manual have a section that tells you how to clean out mineral deposits and hard water scale? Usually, this is done by filling the resevoir with white vinegar and then turning the machine ON for 30 seconds then OFF for 5 minutes. Keep repeating the ON-OFF cleaning cycle until all the vinegar is pumped into the carafe. If the machine needs further cleaning. Repeat the process until the scale and mineral deposits are dissolved. Finally, flush the machine with a full resevoir of clean water and run a normal BREW cycle. Should work like new.
Apr 25, 2015 | Mr. Coffee ECM20 Espresso Machine
CLOGGED SHOWER HEAD - HOW TO CLEAN
You can dip a shower head and CLR or Oxsee clean. You can do it the old-fashioned way and use a needle or a small nail and clean out every little hole or you can run high-pressure water through the opposite end of the showerhead. Little carbon and gasket material finds its way through your screens and filters into your house and comes through your showerhead clogging it. if you can get those clogs out by simply running water backwards through it, you might solve your problem, but you must take it off to do this. simply's unscrew it counterclockwise. it should come off remember to use thread tape to put it back on and make sure the rubber gasket is also inside
Jan 31, 2015 | Dmm Symmons Temptrol II pressure balancing...
Water squirts in different directions while turning the shower on. What could be wrong with it?
It could be due to the dirt or mineral deposits clogged in the showerhead. Unscrew it and give it a good thorough clean and it will work fine. Read more at http://www.mollymaid.co.uk/posts/2013/july/hard-stains-how-to-get-rid-of-them-at-your-holiday-home.aspx
Aug 06, 2013 | Home
Sediment clogging the unit
We live in an area with rather mineralized water. and have had regular issues with this. the best solution we ever had to this sort of problem was to simply descale with a vinegar mix until it ran clean and then go with very regular descaling 9 in our case 2 a week, unitl the dog chewed through the cable). I had my B40 for almost 3 years. Good luck!
May 11, 2017 | Keurig Elite B40 Coffee Maker
I have the Eco Rain showerhead and about half the nozzles are no longer putting out water. How can I clean them out?
Disassemble and soak it in a lime cleaning solution or vinegar. I have include a link below with more information for you. I hope this will solve your problem.
http://www.wikihow.com/Clean-a-Heavily-Clogged-Up-Shower-Head
Jun 16, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Kohler Flipside K-15996-CP Polished Chrome 01 Showerhead Logo
473 people viewed this question
Top Kohler Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Kohler Pool and Spa Expert? Answer questions, earn points and help others
