Toshiba aw 1160 s
I have check the water level sensor,lid sensor and water inlet valve but is still showing the error code E7-4
  • 110 Answers
SOURCE: E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Posted on Dec 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool GHW9100LW2/CSR1903623 flashes a FH code
The "FH" error can have several causes, so this can sometimes be a tricky problem to diagnose. Some of these error codes can also be erroneous. The first step to troubleshooting your problem should be to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer (or brain) of the washer. Sometimes this is all it takes to correct minor glitches. If your error code reappears following a reset, then you know you have a genuine problem. If the "FH" error persists, the following link explains what to do:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Although, you may be correct in your assumption of a possible water inlet valve problem, I would recommend you read through the link provided and try to eliminate the easy things first. Check your installation for a possible siphoning issue, followed by a check of the drain pump. If those items check good, check the sediment screens in the water inlet valve. If you live in an area that has hard water, or if you use well water, the sediment screens can become clogged with deposits and debris. If you suspect a clogged inlet valve you can also remove it and thoroughly clean it in a 50/50 solution of water and distilled vinegar. Allow the inlet valve to soak in the solution for about half an hour and flush real well with clean water. Avoid submerging the solenoids and electrical connections, or getting them wet.
If you have questions along the way, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
Krazytech
  • 725 Answers
SOURCE: ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
Macmarkus
  • 2605 Answers
SOURCE: Asko D3530 water inlet fault code, water valve is
It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like repairclinic.com etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
Posted on Oct 28, 2009
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
How to fix error e23 on toshiba washing machine. machine runs for a whikle and then stops
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Jun 10, 2014 | Frigidaire Affinity ATF7000E Front Load...
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Toshiba washing machine model AW 9790s error code E1
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
I hope this was useful
Feb 15, 2013 | Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Washer starts to fill stops then drains F 81 error code
Whirlpool Error - lid (F81) - Open/Close Lid
NOTE: The letter/number in () is what is saved in the computer/control memory.
lid flashes when the following conditions occur:
? User presses START with lid open.
? User presses START after 2 consecutive machine cycles without opening lid.
? The machine/motor control cannot detect the lid switch opening and closing properly.
Hope helps.
Sep 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 26, 2009 | LG Dishwashers
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
15 people viewed this question
jasbo
jasbo
