Question about KitchenAid Dishwashers
Replace circuit board
My Kitchen aid superba model KUDS01FLSS6 ends up stopping during a cycle and has the flashing light 7 times. I know this means something is wrong with it sensing a water temperature increase. I tested the heater element and it is fine and the machine heats up, but about 20 mins into the cycle it shuts off. I am guessing the control panel needs to be replaced. I just want to make sure I shouldn't check something else before replacing a $140 part. thx
  • KitchenAid Master
  • 3,247 Answers
If you have not already done so, it might be best to run the controller and circuit diagnostic tests before you replace the parts.
Refer to the instructions from this site.
http://applianceguru.com/forum19/24856.html
It is possible the Thermistor may be faulty causing the controller to believe the water is not heating. This will be much cheaper to replace than the controller.
Posted on Feb 16, 2014
Testimonial: "Thanks. I will try that and let you know how it goes."
  • Richard Kalina
    Richard Kalina Feb 16, 2014
    I'm having trouble figuring out how the diagnostics work. I opened the door and pressed the key sequence high temp / energy scrub / hight temp/energy and then start then closed the door. I pulled the dishwasher out so I can see the control panel as it runs, but how do I know it is running through the diagnostic cycle? Sorry for the confusion.
catriver
  • 878 Answers
SOURCE: Whirlpool DU1050 / Clean light flashes 7 times
Cmattson, This problem has been a real pain for owners of this model as well as us techs who repair them. There are a lot of things to check to get to the right problem. First, the water entering the dishwasher should be no less than 120 degrees. During the first 8 minutes of the initial wash cycle, the heater should be on. You can check this by dropping the toe panel and doing some tests. The element will be in the rear, so it can be difficult to get at unless you can pull the unit out some. Make sure the wires to the heating element are on. With a meter, you should be able to verify that the heater is receiving 120V during the first 8 minutes. The main board monitors the thermistor to see if there has been a rise of 4 degrees with water that enters below 110 degrees and 2 degrees with water that enters above 110 degrees. If it does not see this, it will drain and flash the clean light. The element itself should ohm out at 10 to 35 ohms. Other things you might have to check; The heater runs on the nuetral side of the door switch so you want to make sure the d/w is level and the door is closing properly. If the left door switch is not making contact, the element will not heat. Make sure all the harnesses are on tight on the control board. I have found in most of my calls on this problem it was a faulty heater. I've only had one case of a faulty thermistor. Best of luck on this..
Posted on Jun 10, 2006
  • 49 Answers
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Posted on Feb 19, 2008
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
  • 188 Answers
SOURCE: whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
I have a Kitchen Aid Ice maker Md.# KUIS18NNTSO that will not stop making ice when the bin gets full. I have replaced the main board and the thermistor.
There is two thermostats, one to control cycle located under chill plate, other is located on the side of the bin inside. The one on the bin is the one that controls ice level. Part number 2313633, I assume the bin thermostat is the one you replaced. Let me know if you have any other questions to this unit.
Good Luck
Sep 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
8193762)
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
I have a Kitchen Aid KUDKO1ILBS1 which is constantly blinking clean. I have replaced the circuit board once because the capacitors were bulging blown out. After replacing the board the dishwasher has a...
Hi
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Thanks Daniel
Aug 13, 2010 | KitchenAid KUDK01TK - Multiple Color...
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Oven lights not working. replaced both bulbs. both lights still not working. Is this circuit fused, if so, where is fuse located?. First problem on this Kitchen aid Superba in 12 years. John.
The oven lights get power from the main circuit board.
Access the circuit board and check output voltage on board terminals P4-4 to P4-1.
No voltage would be a bad board.
If you get voltage at these terminals the wires or sockets are bad.
The board is not repairable. Only replaceable.
Mar 15, 2009 | KitchenAid Kitchen Ranges
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba ksrg25fkwh05 10-03
Bottom line Steve, I'd place about 97% of my $$$ on the optics board.Change it ,it comes as 2 parts and is a daily issue and is simple to change out. This is the result of Technology making a step in the wrong direction ...........AGAIN !
Steve, I'm Here to Help !
Please Rate This !!! Thank You !!
May 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
May 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Clean light flashing 7 times. Can't start the machine
For KitchenAid Whirlpool KUDS01FLSS0 -- When the clean light is blinking or flashing 7 times in a row and no other front panel controls will work, do the following:
push SaniRinse-EnergySaverDry- SaniRinse - Energy Saver Dry
(Try the Heated Dry button if you don't have a Energy Saver Dry button)
All the lights will then come on as this will put the unit into diagnostic mode.
Then, push Cancel after about 10 seconds. You are no longer locked out. Run the dishwasher normally.
References:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9/$FILE/8178496.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Jan 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
124 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
