Question about Lexmark "x548de multifunction laser printer"
Recovery mode after POR
Key sequence
It is locked and a code that is eo1 is on the screen it is the casio 3700
It simply means you started a sequence then tried to use another mode without finishing the sequence. Turn the key to each mode until the error stops. That is the mode you were last in and you must finish what you started in that mode before you turn the key again.
Feb 11, 2015 | Casio Parts Cash Register PC Desktop
Please help!!! How do I boot my Lenovo into Safe Mode? The F8 key doesn't bring anything up. I do have a "one key recovery," which takes me into a "setup utility" but nowhere is there "safe mode." I'v
You might try going back into your setup and disabling Secure Boot, and look for "verbose" or "full" mode for startup - this will print the entire startup sequence on boot - valuable for troubleshooting hardware and some software issues.
As for the ability to boot to Safe Mode - the process is different for different OS - you can find detailed step for starting in Safe Mode in Win8/8.1 here
Windows Startup Settings including safe mode Windows Help
Nov 20, 2014 | Lenovo G585 15.6-Inch Laptop Glossy Brown...
How do i start window 8 in safe mode?
Press Win+R to get the Run dialog. Type "msconfig" and launch the utility. In this window In the Boot tab, check Safe boot, followed by the type of Safe Mode that you want to achieve. Then Apply
OR
When PC Is Not Starting
when start up sequence is going on you need to pass the BIOS splash screen, hold down the Shift key and repeatedly hit the F8 key. Then you will get enter into recovery mode, but it might take a few tries before you achieve that. Then in new com window click the See advanced repair options button. In the next screen, hit the Troubleshoot button. In the troubleshoot menu, click Advanced options, wherein lies Windows Startup Settings. Choose that. The next you will be asked to restart the PC. Then you can see the familiar Advanced Boot Option screen like XP and you can choose Safe Mode there
Aug 30, 2014 | Ahead Software 8 Ultra Windows
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
Toshiba Satellite Pro 4600 laptop
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
Apr 25, 2012 | Toshiba Computers & Internet
I tried to do a system recovery by restarting the computer and holding the f11 key but it wont go in to the restore screen mode
You have to keep pressing it during the boot sequence. Can you get F8 to work? You can try having windows restore your last known good configuration.
Apr 15, 2011 | eMachines W3611 PC Desktop
Wont go into safe mode or boot from cd menu
F10 is usually the boot sequence key for most laptops. but you posted in the ACER section for a DELL so its a little diicult to decide which information to give you other tha F10
You could always watch the boot sequece as quite often there will be a message there to offer you an option of chanhe boot device or even a recovery option
Aug 17, 2009 | Acer Aspire One PC Notebook
Blue Screen and error message at boot up
You can find the recovery sequence for your machine at Dell's support site. Bellow is a link to Dell support. Keep in mind that a blue screen indicates an operating system error, and may be caused by a hard drive failure. If this error is due to a hard drive failure the built in automated system recovery will not work, because it's stored on the hard drive.
http://support.dell.com/
Aug 25, 2008 | Dell INSPIRON 6000 CENTRINO...
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
Lexmark "x548de multifunction laser printer" Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
