Question about Gateway MX8710 PA6A COMPATIBLE LAPTOP LCD SCREEN 17 WXGA+ MATTE CCFL (22099231271)
Gateway mx 8710 .plugged in no charge has new battery
Computer works fine ,replaced battery.However doesn't charge new battery .I've tried device manager fix on line repair idea's from people cant seem to get it to work
    New Friend:
I have the same problem. I went into Bios (F2) to calibrate the battery. It gave me a flashing red warning that the battery was being overcharged. Looked at the battery, which is 11 volts. The laptop charges and powers on with 19 volts. I looked online for replacements batteries. Some were like mine - 11 volts. Others were over 14 volts. Look at the voltage of your old battery and see what is its voltage. Good luck.
Posted on May 24, 2015
    Master:
  • Gateway Master
  • 788 Answers
There are 2 possibilities:
1. The internal charger does not work,
2. You received a defective battery (some after market batteries are very poor quality batteries).
Posted on Mar 04, 2014
I have Sony Vaio laptop, it seems to have issues with charging the battery, I've replaced the battery twice to new original Sony batteries but still it shows "battery connected but not charging" o
either the powersupply your using isnt correct, go to
start
right click computer
manage
device manager
check your ac there
2.
your charging unit has gone and may need re soldering
Mar 30, 2013 | Computers & Internet
Tip
How to solve the "Battery Plugged in not charging"
Battery Plugged in not charging and not detected solution I have a Dell Vostro 1510 laptop, and when i have the battery charger plugged in, the battery icon says "10% available (plugged in, not charging)", and if i pull out the cord, the laptop shuts down straight away. Can this be fixed, and if so, how? I bought this laptop new around 6 months ago. The detail info below:
plugged-in-not-charging.jpg The Battery didn't charge or detect being plugged in also caused by four reasons:
  • 1. The laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell Motherboard Problem
  • 4. The laptop bios is too old to recognize the battery
After I checked my battery and adapter and confirm they are good. Then I try to repair it by myself.. My Latitude E6400 battery was fixed by myself.
The first solution :I search in the google: Repairman from another site suggested that while the computer is on and plugged in, to unplug the adapter and then plug it back in again. To check the computer can started charging.
So I remove the laptop battery from the laptop and left the AC cord connected, booting it up on the power cord alone until I was able to boot into Windows 7, at which point I then put the laptop battery back into the computer while it was still on. This worked and while a tad unsafe for most people, I wouldn’t recommend you use this idea unless you absolutely had to, that is, if there was no other choice.
The Second Solution: You can download the newest BIOS from dell.com and then flash the bios. But I do not want to update Bios, So I use another way to make the Power manager system to recognize my battery :)
I open up my laptop Device Manager (usually a right click on your Computer/My Computer) and remove all Dell inspiron 6400 battery related devices from the Device Manager. Then after you’ve done that, right click again and select “Scan for Changes”, which should reinstall the proper services and allow for your laptop to charge again. See the more info in the image below.
remove-battery.png If this also can not solve the problem, I suggest you send the laptop to Dell to repair the Laptop motherboard.
The article Via laptop battery blog
on May 27, 2010 | Computers & Internet
Doesn't recognice drive
In my limited experience such things are caused by software conflicts where substandard software replaces parts of the operating system or approved programmes with other versions. The displaced software might be lost or deleted but the operating system tries to repair things and fails.
Nero burning software seems particularly bad, working fine when first loaded but deteriorating after every restart until finally it stops working altogether but deleting it doesn't fully restore previous functionality.
Nov 12, 2017 | LG SuperMulti Portable Slim DVD Rewriter...
Dell Inspiron e1405 Laptop. Why won't the battery charge?
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that
the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by
using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select
Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes.
Please let me know if it's works or not and thanks for using fixya
Sep 03, 2012 | IBM ThinkPad Computers & Internet
What'My laptop works fine when I have just the battery but when I plug it in it does not work even without the battery. Could it be the Adapter cause all my outlets work and so does the battery.s
if the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Compaq Presario CQ50-215NR Notebook
If the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Please let me know if it's working
Aug 26, 2012 | HP Compaq Presario CQ50-110US Notebook
Toshiba c650 repair manual
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Toshiba Computers & Internet
Battery not charging in lenovo y410 laptop
Aug 03, 2012 | Lenovo 3000 Y410 Laptop
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Gateway MX8710 PA6A COMPATIBLE LAPTOP LCD SCREEN 17 WXGA+ MATTE CCFL (22099231271) Logo
126 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
