Question about Ovens
Ck414 oven is burning food at the back of the main oven, how can i repair this?
3 Suggested Answers
SOURCE: Oven bakes unevenly and burns food
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
Posted on Oct 14, 2008
  • 106 Answers
SOURCE: Not heating up to required temperature and burning food at back
some elements are bunt please check and an replace
Posted on Jun 15, 2010
Temperature controls
Ok, I need some information from your to answer this question correctly. 1. How long is your preheat time? Must allow 30 mins for the oven to heat and settle, failure to do this you will have temperature issues, usually burning food. This unit was designed to use both elements to preheat, so inserting food too early will burn your food. 2. What rack position did you select for the product you cooked? This is really important!!! I am a certified tech and I understand this issue you have, but information is key to answer this for you. Most people don't read the instruction manual and treat this oven as all the others on the market. As the ovens get more features, its important to learn how to operate as instructed to avoid these issue and have a great turn out of good food at the same time. Please get back to me if you would like more help. Thanks Gere
Apr 07, 2014 | Viking Ovens
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
I can not control the oven temperature. When I turn on the oven the temperature keeps increase the food will burned.
You need to replace the thermostat for the oven. This consists of the switch on the panel and a long capillary tube and a small bulb. Remember to switch off the oven wall switch or the mains if you are attempting the job yourself.
Jan 23, 2011 | Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
MAIN OVEN DOES NOT TURN ON HIGH
this could be the thermostat or the main oven element this sheet might help. For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Smeg Ovens
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
Oven does not start. checked owner's manual. Still does not start. The control panel works and does not display a problem code. The broiler and top burners work. Ideas?
Hi
You must check the main power wires where they enter the range at the T-block, sometimes they can burn off. Also check house fuses (or breaker) that supplies power to the range. Checking with a volt meter, you should get 240 volts between the black and red main power wires. The range receptacle and power cord can also burn and fail. Also check the fuse/circuit breaker and check to see if power is getting to the range/oven. If anything does not turn on then check for a blown fuse or tripped circuit breaker. Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to. There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | Magic Chef Ovens
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
