Question about Breville BCG450XL Manual Burr Grinder
I install a new switch; Have electricity both side of the switch. But the grinder do'nt start
You mention this grinder has a fuse. Can you explain to me how can I verify the fuse?
Coffee grinder wont start
Its been a while since i worked on a grind master so have a little patience with me. First, if the breaker went then there might be something blocking the burr chamber like a rock or screw or other obstruction. Second I would check the micro switch for the bag holder if there is one on your model using an ohms meter.
Mar 16, 2012 | Grindmaster 875 Electric Burr Grinder
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Stalled... won't grind... makes no sound... it is 5 years old...
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
May 21, 2009 | Solis Maestro G385 Electric Burr Grinder
The grinder will not start
check the mechanism is not blocked, undo the screws at the front. Remove the baseplate, there is a 1.25 a fuse attached to it under a black plastic cover. If neither of these thing work, is there a burning smell?
Could be the motor. I imagine it is just the fuse.
Mar 13, 2009 | KitchenAid (KPCG100ER) Electric Burr...
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Insert a screw driver into the **** and pry gently outward with a
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Switch Broke
I don't know about the switch going inside but you can contact baratza and they will send you a new knob that won't fall off for free.
Nov 25, 2008 | Baratza Maestro Plus (G385) Electric Burr...
No power bunn-o-matic
Look on the right side of the grinder, there is little cover. Pop the cover off and press the reset button.
Sep 10, 2008 | Bunn -o-Matic G3 (3 lb. Commercial Coffee...
Won't come on?
I just bought a brand new unit and as recommended I unscrewed the top bean hopper and the coffee ground container-cleaned and wiped.After that I screwed back everything and tried to grind some beans.The timer was ticking away but the grinder just refused to start.I switched off the main and unscrewed the hopper and carefully screwed it back.Halfway through,I noticed and felt that you must balanced and screwed it with a smooth movement until the the whole piece is in place.The grinder just started without a hitch.This grinder has a protection circuit whereby if any part is not properly installed it will not start.
Mar 07, 2008 | DeLonghi Retro DCG59 Electric Burr Grinder
Salton perfect touch electric grinder - thermal switch/fuse
This is most likely a thermo overload, and can be replaced, make sure that there is no short circut before replacing it, as it will only blow again if there is a short. This part can be purchased at any Radio Shack store.
Jan 26, 2008 | Salton Perfect Touch Electric Blades...
Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Jan 01, 2008 | Krups GVX2-12 Electric Burr Grinder
Breville BCG450XL Manual Burr Grinder Logo
80 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
