Question about ASUS Eee Top ET2203T (ET2203TB0317) 21.6 in. PC Desktop
Open up a et2203t case - ASUS Eee Top ET2203T (ET2203TB0317) 21.6 in. PC Desktop
How to open case?
under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Oct 27, 2012 | Namco Arcade Classics Plug and Play TV...
Asus eetop 2203t overheating cpu
The heat-sink copper pipe contains a liquid coolant inside. If this leaks (and it definitely does in some cases) the CPU will rapidly overheat.
To fix the problem you can either purchase a replacement part or cut holes in the case (not an easy task) and add an additional external fan over the CPU.
Feb 15, 2012 | ASUS Eee Top ET2203T (ET2203TB0317) 21.6...
How to restore asus eee top et2203t to factory settings
One way to clear an Asus PC of problems or viruses is to restore it to its original factory settings. This will wipe the computer clean and give you a fresh start. The idea of restoring your laptop may be intimidating, but there is no programming involved. In fact, these laptops are designed to be restored in a short period of time.
1Turn off the Eee PC. Press the power button or select the shut down option from the computer's main desktop screen.
2.Turn the unit on and press the "F9" when the flash (logo) screen appears. A menu will appear with a list of options to choose from.
3.Select the "Restore Factory Settings" option from the bottom of the list in the menu and type "Yes" when prompted to verify the reset.
4.Press "Enter" when prompted by the computer to reboot the system. Wait a few seconds for the system to reboot.
5.Follow the prompts on screen to accept the licensing agreement and configure your settings.
Sep 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ET2203t eee mouse and keybaord wont work
Make sure you "synchronize" the wireless
unit(s) with the base unit(plugged into computer)-click buttons on each to sync: first one, then the other-This needs to be done each time batteries are replaced.
Hope this helps.
Mar 04, 2010 | ASUS Eee Top ET2203TB0317 216Inch Black...
How do I open the case of a 1968 automatic, ambassador Bulova watch? It appears that there is no way to open the back.
Pull out the crown. Now try to pull out it more, just don't do too hard. If the stem does not come out, there is the way you can open the watch - if it does not, then you have a monoblock case and it can be opened by the special pump only. In case if you can not pull the stem out, take an eyeglass and examine case back all the way around the case. You have to see the tiny groove. This is the place where to insert the openers blade and pry it .
Rate me, plz.
Jan 25, 2010 | Watches
Can;t open back of watchto find date it was made do i need special tool or some thing else can be used
You definitely need special Rolex case back opener. Without it your watch will be locked forever. Rolex cases are so tight, that even when special opener is used, you will need quite strong arms to open it. Rolex case openers sometimes sells on ebay, but they are never cheap.
Jan 07, 2010 | Rolex Daytona 116520 Wrist Watch
Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Bulova Watch
Can not open case to install 2.5
The wheel probably is an OFF/ON switch.
Take a closer look for small screws. If you see none, then what you probably have is a "press-fit" case -- like the lid on a bottle of ketchup -- that takes some pressure to force the case to open.
If you just recently bought the case, take it back to the store that sold it to you, and get them to demonstrate how to open the case.
Dec 29, 2009 | Computers & Internet
ASUS Eee Top ET2203T (ET2203TB0317) 21.6 in. PC Desktop Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
