Question about Bosch Saws
3915 saw guard problems - Bosch Saws
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
Ryobi TS-254 blade guard does not retract when blade is lowered
Probably something jammed up inside the body of the saw where the guard retracts, like a chip of wood. I once had the same problem with my circular saw guard not retracting. Turned out there was a screw that had somehow gotten trapped in there and once that was removed, guard functions perfectly now. Definitely sort it out as soon as possible because this is very dangerous--you could make a cut, rest the saw on your leg and... earn a quick trip to the emergency room.
Aug 11, 2011 | Ryobi Saws
Problem appears to be the blade guard 'hanging-up' on the down cut. at the very beginning of the action the body of the saw sticks and only after briefly helping the guard up manually does the saw...
first make sure the blade guard is correctly tightened. then if that is correct you have a problem with the link bar and the center plate of the guard. they might be worn or not smooth, I generally try to sand both surfaces cleanly and apply a dry lubricant to them to ensure proper movement. If that does not work they would need to be replaced.
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
I reassembled the blade guard after cleaning and found that the blade guard prevents the saw from lowering. Is it possible to get the spring in backwards? If I move the guard up an inch, everything works...
Had the same problem with the dewalt, either the lifter arm is bent just enough or some thing is worn just enough, we put a zip tie on the part where the saw comes up to rest and it works fine.
Feb 05, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
Power Glide Circular Saw with Laser Guard Spring Broken
The spring hooks onto the blade guard and wraps around the hub of the blade guard. It is orta hard to see but it will hook onto the guard.
Feb 11, 2009 | Ace Hardware Power Glide Circular Saw with...
Saws Logo
71 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
