Question about Electrolux Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
We recently bought a 2nd hand Electrolux oven, over 3 months ago so outside the warranty of the shop. When it's a double oven, with the top oven combined with the grill. When you turn the gas on for the grill, hold down the knob, it will ignite ok but when you release the knob, the gas goes off. There is supposed to be a short time where you hold it down before the grill gas stays on but now no matter how long the grill is alight, it won't stay on after the knob is released. The oven side is fine, though, so I think it's something to do with the heat sensing node but don't know how to fix. Any ideas please?
    Top Expert:
  • Electrolux Master
  • 26,138 Answers
I would arrange a service call from a registered gas safe engineer.
Posted on Apr 13, 2017
4 Suggested Answers
philbran
  • 242 Answers
SOURCE: Flame will not stay lit in oven of countrychef 100g
Yes very simple. There is a bulb the flame is heating with a small tube that runs to the gas valve this is the saftey sensor that is bad called a thermo-couple , they are common to go out and should be easy to find online. Let me know if you have any other questions.
Phil
Posted on Apr 10, 2009
  • 40 Answers
SOURCE: grill will not stay on when I release the knob,
hi, sounds like the thermocouple, when heated it produces a small current to allow the gas valve to stay energised. they can break, so the current cannot pass through. hope this helps
Posted on Apr 10, 2010
Testimonial: "thank you for your time and expertise."
  • 3 Answers
SOURCE: westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Posted on Feb 16, 2012
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Grill will not stay on when I release the knob, the gas goes out
Apr 10, 2010 | Ovens
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
