Question about Verizon V100AM2 Cordless Phone
I need a manual for Verizon 100/100am cordless phone
It says I need a pin # to register a phone. I don't know where to find a pin number. I would like to have the complete manual.
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
I have philips se4502b/17 cordless phone but it remains on searching mode i tried my best to register it but not succeeded
Sorry this comes late, but we just went through this problem with our unit, but I hope this helps someone else out there.
We had the same problem. To fix this, you need to do a few things and hopefully it will work for you.
First, do you have the PIN that came standard on the phone? The standard PIN for these phones is 1234. Go to the advanced settings, and then REGISTER, and put the PIN in and allow it to go through the "registering..." mode. It even may beep and say "unregistered" but don't give up hope, If this happens, unplug the unit from your outlet and wait a few minutes, plug back in, and place the handset on the base. It should then work.
Mar 28, 2011 | Philips SE4502B/17 1-Line Cordless Phone
I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
I have a siemens gigaset S455 i had to take the phone to a new house that im going to rent next month to find out the new phone number back home i need to register the handsets (x2) and cant find the...
unplug the base and press the register button. (it's the round one to the left of the minus button) holding the register button plug the base in and continue to hold the register button for at least two seconds. you should hear a beep. the pin has been reset to 0000.
Dec 07, 2008 | Siemens Gigaset S455 Cordless Phone
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Philips CD130 Cordless Phone User Manual
registering again didn't work for me. I used the following steps
1. close the handset (long-press red button)
2. discconect the base unit from the power source
3. reconnect to the power source and long press the intercom (the only button on the base unit) for 5 seconds.
4. turn on the handset (long-press red button)
with 2 seconds and it will be connected again.
hope this helps.
Jan 25, 2008 | Lands Phones
Verizon V100AM2 Cordless Phone Logo
32 people viewed this question
Top Verizon Lands Phones Experts
Are you a Verizon Lands Phone Expert? Answer questions, earn points and help others
