Question about Mackie Onyx 1640i Mixer
How to set up my mixer
I bought this mixer and did the plug and play with firewire. Its not being recognized by my Imac 10.6.8 snow leopard or leopard. Using logic 9 my m-audio project mix interface with a presonus digimax fs pre-amp is recognized . I have 16 channels of in and out with those but not 32 with the firewire daisy-chain or all three. Is it true that mackie 1640i does not work with leopard or snow leopard? HELP PLEASE. I have an IMAC 10.6.8 , snow leopard, logic pro 9.
2 Suggested Answers
  • 5603 Answers
SOURCE: I just got a mackie 1640i mixer yesterday. I
Likely you haven't got the levels set properly. Start with the trim controls (head end gain) Make sure you are not clipping there. Also verify you aren't overdriving your amps. Remember that the outs are line level, not mic level so the gain oof following equipment needs to be set for line level.
ALWAYS USE balanced audio line from this unit... either XLR or TRS type cables. ALWAYS power ALL interconnected equipment from teh same receptacle or source to avoid ground bounce damage to circuitry. You don't say what you are using to record with. Make sure it has balanced inputs. For instance, connecting cables from this to the audio input jack of a PC which is unbalanced would be a disaster in audio quality. There would be a problem of levels and the unbalanced thing... You haven't given us enough information of your hardware configuration to analyze the problem more than what I have said here.
Posted on Dec 26, 2010
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hi im sorry if this sounds a little dumb!!! last weekend while i was on a gig i tried to hook up my lap top to my mackie mixer (cfx12) but i wasnt able to get winamp to play through it, which channels...
With a stereo splitter cable that takes the stereo 1/8 plug of the computer into two RCA plugs you could go into the "Tape Input" of the mixer... OR take a 1/8 stereo splitter cable from the PC splitting to a pair of 1/4 inch plugs go into one of the 4 stereo input pairs on the mixer... like 7 and 8 or 9 and 10 for example.
Dec 22, 2010 | Mackie 1202vlz3 12 Channel Mixer
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Pc not recognizing phonic helix 18 universal mixer
I have a Yamaha AW1600 and I had to go into my firewall settings and add it to my exceptions to allow the program access to my computer through the firewall. This may help. Thanks!
May 30, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Mackie Onyx 1640i Mixer Logo
23 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
