Question about Edirol V4 Video Mixer With Effects
Edirol v-4 power supply - Edirol V4 Video Mixer With Effects
  • Edirol Master
  • 3,368 Answers
What do you want to know
Posted on Dec 10, 2014
Edirol ua-5 flashing power light flashing
Be aware that SCMS "prohibited" recordings will trip this flashing light, and will not output. You will have to make an analog copy.
Feb 25, 2012 | Edirol UA-25 External Sound System
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
No power but works through usb
Checkthe 9volt dc adaptor with a volt meter to make sure it is supplying the unit with power. Does the power indicator light come on when you plug it into the wall? if the power adaptor is supplying power, then next i would check for an internal OR external fuse around where the power plugs in, also making sure the plug it plugs into is not loose or wiggling as this could mean the female portion of the plug may have bad soldering or has been broken. please post again here with your findings... Regards
Jun 21, 2010 | Edirol SD20 Studio Canvas USB/Serial/MIDI...
My FA-66 is connected to my MacBook Pro via Firewire. When I plug a secondary display in, it makes lots of extraneous noise, even worse if the PSU is not connected to the MacBook Pro. What is causing this?
Is the noise a constant hum? If it is such a noise, I suspect a faulty or poor performing power supply. Check the power supply that powers Edirol sound card for any improper ground. Another custom made power supply which is properly regulated (voltage) and at a higher ampere rate would be an idea to consider. I think your main issue is grounding because you say the case become worse when the MacBook PSU is not there. Because, you are loosing a ground path when you remove the PSU. Then it solely depends on the Edirol ground path. If that path not a good source of ground, there lies your problem.
Mar 09, 2010 | Edirol FA-66 Sound Card
LOT OF HISS I HEAR . HOW TO REDUCE IT ......
Since the edirol is USB powered try using it without any other USB devices connected. Maybe some USB disk or flash takes much power from the USB and the edirol works with less power. If in that case works fine, plug in the other USB devices on by one to find where is the problem. Always check the line input of the edirol, cause mic input makes too mauch amplification and the noise level is critical.
Stelios.
Feb 21, 2010 | Edirol UA-4FX External Sound System
Edirol fa-66
1.i gained info about the mains supply data (9 volts 2 a, minus pole in the center pole of the plug) which is a quite exotic supply in comparison to standard devices with 12 volts an plus pole in the center pole ...
the fa 66 didn't work , when connected by 4 to 4 or 4 to 6 firewire cable .
my laptop only has a small 4 pole socket.
therefore i suppose that through this 4-pole socket and cable there was no current lead through.
after additionally connecting the fa-66 with mains supply AND 4 to 6 (fa 66 side) cable ... it finally worked.
the manufacturer should print all relevant data directly to the fa 66 device near by the socket und also print "FA-66" onto the supply ... because i own lots of alike-looking supplys and it's a drag to find out which ist good for what...
Mar 23, 2009 | Edirol FA-66 (FA66)
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Aug 19, 2006 | Edirol UA-101 External Sound System
Edirol V4 Video Mixer With Effects Logo
315 people viewed this question
Top Edirol Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Edirol Audio Player and Recorder Expert? Answer questions, earn points and help others
