Question about Hotpoint HSS25GFTWW 25.0 cu. ft. Side by Side Refrigerator with GE
Ge hotpoint hss25gfta ww main control board isn't on ever since a power outage. Fridge lights are on, but it's not cooling/freezing anymore.
No lights on main control panel. not cooling or freezing anymore. lights are still on in the fridge cooling slightly
    Top Expert:
  • Hotpoint Master
  • 51,126 Answers
Have a fridge technician as the power surge from the outage may have damaged the power board.
Posted on May 25, 2015
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
woodchuck789
  • 4070 Answers
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
My fridge and freezer stopped working. Nothing's running. It doesn't cool or freeze. None of the mechanical parts are working. Only the lightbulb turns on. What can be wrong?
if removing the mother board made no difference to the fridge operation then it would be logical that the mother board is faulty
These machines do not like power surges( can originate many miles away)
have a technician check it out
May 06, 2015 | GE Refrigerators
My Hotpoint Side-by-side temperature flucuates(model #HSS25GFTA). Items in freezer melt at times and then re-freeze. Same is noted for the fridge. Service tech added freon; however, problem continued. ...
You are correct on your evaluation of the " tech " the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Sep 23, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hi i have a hotpoint hss25gfpj ww side by side
Very common. Most likely you need a main control board, located in the back of the fridge.
GE refrigerator repair in orange county, ca
Feb 06, 2010 | Hotpoint HSS25GFP Side by Side...
GE refrigerator not cooling after power outage
It sounds like the main control board is bad . After looking up the board , it is on a recall lisr by GE . You should call GE and have them come and check it .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Nov 02, 2009 | GE Refrigerators
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
Hotpoint HSS25GFTWW 25.0 cu. ft. Side by Side Refrigerator with GE Logo
544 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
