Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Water leaking under washer
Had a bad squeal. I removed pump, cleaned, lubed and replaced.Noise is eliminated however, water runs from beneath washer when using.about 1/4 cup what could be leaking
    New Friend:
Chances are it's the 6 inch or so rubber "U" tube you see attached from the diverter valve to the pump. The end that goes to the pump has to slip under the metal housing and turn it about a half an inch, then use the clamps to secure it.
Posted on Feb 18, 2014
SOURCE: water leak
We replaced our pump motor about a year ago it cost about $65.00 Couldnt find a repair center in Portland Or. area, did it ourselves. Fairly easy. We ordered the part from the appliance center where we purchased about 10years earlier
Posted on Sep 14, 2007
SOURCE: Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Posted on Jun 02, 2009
  • 125 Answers
SOURCE: Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Posted on Aug 23, 2009
SOURCE: Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Posted on Mar 30, 2010
  • 1382 Answers
SOURCE: water leaking on my fisher paykel washer. does it
Hi, It is due to a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking. .
Posted on Apr 14, 2010
Vehicle heats up very fast and I get no heat out of the dashboard. The upper hose is hot but the lower hose is cold after running the engine overheats. When I started it, the belt was squealing. Aft
START WITH THE BASICS. CLEAN, FULL 50/50 MIX IN SYSTEM. CHANGE THERMOSTAT. LOOK FOR TRACES OF COOLANT LOSS FROM THE WEEP HOLE IN BOTTOM OF WATER PUMP (USUALLY UNDER PULLEY). WATER PUMP DRIVE BELT OR SERPENTINE BELT MAY NEED TO BE REPLACED. ALSO MAKE SURE RADIATOR CAP IS WORKING PROPERLY.CHECK FOR LEAKS ANT WHERE ELSE IN ENGINE AREA.
Dec 02, 2014 | 2004 Pontiac Montana
Was squeeling at waterpump.replaced with new pump.squeal went away.after it idled abot 20 minutes,it started to chip,then squeal again.is it possible trhe new bering in water pump,was not lubed?,,and went...
Hi,The water pump is assembled with a sealed bearing (lubed from the manufacturer)
Usually you can feel play in the bearing when its worn.
The seal of the water pump will squeal if it runs without water (it needs the coolant to lubricate it )
So is it possible there`s an air lock in the pump area of the coolant system
Other than that the noise could be coming from something else that the same belt drives
John (South Wales uk)
Apr 16, 2011 | 2000 Chevrolet Venture
Dishwasher makes a lot of mechanical noise when running
If your dishwasher seems noisy, check these:
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
1 Look at the heater fan to check for rusty or squeaky parts. If defective parts are found, replace the fan. If not, go on to the next step.
2 Replace the water inlet valve, which is located at the bottom of one of the sides of the dishwasher, beneath the lower access panel. As a water inlet valve ages, it can sometimes slowly stop working correctly, switching between "on" and "off" every few seconds. This can cause a shaking and rattling noise. If this does not fix the noise, go on to the next step.
3 Remove the lower rack and the lower spray arm from the dishwasher, removing any screws as needed to do so.
4 Beneath the lower spray arm is a pump that contains a propeller. Check the pump for debris (like small bones, seeds, or fragments of glass) that might be causing the noise. If this does not fix the noise, go on to the next step.
5 Beneath the pump is the dishwasher's motor. Check to see if the plastic dish at the top of the motor has broken off. If it has, it may be rattling when the motor is on and causing the noise. In this case, replace the entire motor.
6 Check the bearings on the motor. If they are worn out, replace them.
7 If you cannot trace the noise to its source, try replacing the motor.
Sep 03, 2010 | LG Dishwashers
High pitched noise
This is a water pump about to blow, or a clogged filter or hose. The fact that you hear it immediately, and limited water level is involved, it's pretty much your bingo.
After turning off the water supply, unscrew the garden hose-like attachments for hot and cold water intake. There is sometimes a small filter right there where the water enters. If they're clogged, clean em.
Take the hoses and run them through an outside plug to make sure they aren't clogged with back flowed dirt from the filter and hard water.
If it still won't fill, you'll need to test the pump.
each machine is different, but if you follow the hoses from where your hoses enter the machine, you should be able to unscrew them at the other end.
Stick them in a deep bucket then turn on the machine and see what the pump does. Is the noise coming from it? (service or replace). Does water gush out of the pump into the bucket? (clean all hoses and filters, buy some machine grease and lube all the moving parts, including opening the water pump and giving it a generous amount of grease.
Put it all back and your squeal will one way or another be gone and you'll have plenty of water
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Yesterday made a grinding noise and leaked water out on the floor from under unit.it still works
The noise would be indeed coming from the water pump.
To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump.
Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor.
Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. Check if anything jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.
For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
The first thing I would do is to inspect the inner tub. Empty your washer and carefully check all holes inside the inner tub and under the agitator for any foreign objects and remove if any.
If it's nothing there then you have to remove the front panel. Tape the lid to the top panel. Using a putty knife push in to release top panel clips on both sides. Lift up the top panel toward the back.
Remove the screws on top of the front panel on each side. Pull out the top of the front panel toward yourself for about 30 degrees and release it from the bottom clips. Now you have an access to inside the washer. Run the washer without the front panel and try to locate the sound. Let me know your findings.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The dishwasher makes a horribly loud sound when running. I think it has to do with the lower "spinner arm". When I push it manually, it wobbles and makes noise. So I am guessing that spinning at higher...
It's noisy If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Nov 19, 2009 | Whirlpool Dishwashers
Motor will run but no water comes into dishwasher
Water-inlet valve
Motor
Heater fan
Pump
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Jul 24, 2009 | Dishwashers
Dishwasher making loud noise during wash cycle
Water-inlet valve
Motor
Heater fan
Pump
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
