Question about Garmin Nuvi 660 GPS Receiver
My PROSCAN PLT7777G-Q stuck on ANDROID screen
When turning on it won't go past the ANDROID screen
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
When I TURN ON ALL I GET IS android FLASHING ACROSS THE SCREEN
Hi Brenda, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
May 08, 2016 | Proscan 8 4GB Android 4.1 Tablet
What can I d to factory reset my pros can plt7777G tablet.
Hi Patricia,
You can perform a reset / hard reset to completely wipe out the Android phone this will also remove any passwords and configurations.
Note : To perform this process on your own risk
Step by step guide to reset proscan Android Tablet PLT7777G-Q
Step 1: First, turn off the tablet.
Step 2: Press and hold the power button and quickly poke the reset hole until you see an Android logo on screen.
Step 3: Use the paper clip to poke the hole to navigate until you go in to the Wipe data or Factory reset.
Step 4: Use the power button to select and you should be able to see the screen menu.
Step 5: Select the Delete all user data and restart and it will process it then select restart/reboot after the reset.
Once you have reset the device back to factory settings, all data will be deleted and cannot be recovered.
Or: you can also do this by going into the proscan Android Tablet PLT7777G-Q`s settings>backup and reset and selecting the factory data reset option.
Jan 15, 2015 | Tablets & eReaders
What do I do if my proscan PLT7777G-Q tablet won't
plug in the usb an power it up/down alternately till it asks to recover it take your time
Oct 19, 2014 | Tablets & eReaders
I have a proscan tablet plt7777g. It will not load it turns on and gets to part where it says android but it just stays there.
First Turn off the Tablet, and locate the small pin hole reset.
Press and Hold the Power button while poking the hidden reset button with a small object like a paper clip until you see the Android logo, let off the power button.
Use the paper clip and poke the hole to navigate the menu, hit the power button to accept the menu items.
First select Wipe Data if avialable, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
This is a common problem with these off name tablets, be weary when buying cheap devices.
Oct 11, 2014 | Tablets & eReaders
How to fix my proscan PLT7777G-Q
Try a back-up & reset option, if you can select its settings.
Jul 01, 2014 | Computers & Internet
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan Tablet locked out
Got a proscan #plt7777g-q for xmas, and now it won't open
Jan 21, 2014 | Proscan 8" Tablet with 4GB Memory
Proscan plt7777g-q
I got a proscan for xmas, now it will not open #plt7777p-g
Dec 26, 2013 | Proscan 8" Tablet with 4GB Memory
Garmin Nuvi 660 GPS Receiver Logo
150 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
