Question about Pioneer Car Audio & Video
Disconnection error on Pioneer PDX Z9 internet radio
Internet radio picks up channels and starts playing but drops out with 'Disconection Error' message on display, then will pick up and play for a short while again. Have changed the network cable, also a laptop picks up and plays 'vTuner' station without a problem (which the Pioneer uses)
Duncan
  • 218 Answers
SOURCE: Error message on display of my Pioneer DEH-P8000R
Try buying a cleaning CD that will clean the laser lens and see if that helps. Otherwise it sounds like a trip to the repair shop for you. Good luck.
Posted on Feb 02, 2007
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
SOURCE: kd-g322 error code query
I unpluged all the wires for one more time and it works again!!!
I think the problem is that one or some wires are damaged because they are pressed between the unit and its case. I also shaked them up and down and for now, it is ok. Try it!!
If this works for more than one day, I' ll let you know...
Posted on Feb 23, 2008
SOURCE: Pioneer automotive stereo cd player error 11
I have the same problem now too. It shows up error 11, 12 or 17. I tried using a cleaning CD but did not work. I think the lens needs to be replaced.
Posted on Aug 06, 2008
SOURCE: Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Posted on Aug 24, 2008
Internet radio format error
Hi, I've had an internet radio for several years from what I have heard and this varys with age of the radio most of them play MP3 or WMA formats.
Recently some European stations did some sort of upgrade or are using a different file format which the stand alone internet radio chip sets cannot decipher. I've seen this question asked by owners of many internet radios. Apparently the problem is unique to the stand alone internet radios. Mine says the software is current and with about 16,000 channels I just look for another station. If you are listening on a computer rather than a stand alone you probably can upgrade the software and the station will continue to play. apparently the problem lies with the chip sets in the radios and someone coming up with another format or tweak to it for the transmitting stations which the radios cannot handle. Some radios handle it better than others.... The problem is not with the radios as such but with the transmitting stations doing something either new or out of standard depending on who yu talk to.
Feb 02, 2014 | Cameras
I have a proscan PLT7223g tablet and trying to download app from goolge play store and I'm getting error code 911 What is this and how do I fix it
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
Jan 16, 2014 | Tablets & eReaders
I have a 1989 oldmosbil cutlass ciera and i upgraded to a new pioneer radio and it keeps saying amp error after a few moments of playing . What do i do
This is referring to the internal amp. Make sure none of the speaker wires are touching each other or metal. if the only speakers hooked up are the 6x9's then one or both of them probably has a bad voicecoil and is shorting out causing the radio to protect itself. Replace the 6x9's and you should be okay.
Jan 14, 2014 | Clarion DXZ438R CD Player
Unable to resume downloading after internet
call the phone company they will help over the phone
Apr 24, 2010 | Microsoft Internet Explorer 8
I CAN'T SIGN IN TO PLAY STAITION NETWORK ERROR CODE (80710092)
ERROR CODE (80710092) can mean incorrect password, incorrect user name or bad internet connection check your user name and password and if that doesn't work then disconnect your ps3 from the internet and then reconnect
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Yesterday I discovered how to connect my Dsi to the internet, and it was great. Prior to going on the internet via my DSi i was playing Style Boutique via on my dstti card. after i played it, i connected...
Ok you have to disconnect to the internet by loading up the internet screen and touching disconnect, once you have done this you should be able to play your games.
Jan 20, 2010 | Nintendo DSi White Console
Why do I get an error code when trying to download a game to my Wii Memory?
Any time I have tried to download from Nintendo Shopping channel, I have gotten an error for one of a few reasons. 1. No Internet Connection. 2. Slow Connection, 3. Connection Drop. or 4. operating system error.
If you provide the error code or look it up on Nintendos website, it usually gives your some hints to fix your issue.
However, here are the most common:
1. This is usually because the WII console is not connecting to the router or getting an IP address. If could also mean your router has lost its connection to the internet (easily checked with any other computer).
2. This is usually due to congestion (per Nintendo) in your area. They say to try changing your channel for the router. I think Nintendo recommends 6 or 11 but it depends on how many people in near you use wireless.
3. This can be a number of things. This time of year, you typically have problems accessing/downloading things from Nintendo just because a lot of people are trying. However, I have wireless N and the WII is wireless G; I have found that sometimes causes drops. Wireless N is constantly trying to get the best signal and sometimes changes channels (at least mine does), this can cause G to drop sometimes. I went to a wired solution, it helps in online play.
4. I have not seen this one of late. But when WII first came out, an update disabled WII connect and Nintendo had to replace the unit.
Jan 01, 2010 | Nintendo Wii Console
Error Code: E-12
The laser pick up is bad, needs to be replaced.
Apr 21, 2008 | Pioneer DEH-P6800MP CD Player
Error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Nov 17, 2007 | Pioneer GPS AVIC-X1 car radio
Car Audio & Video Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
