Question about Kenmore Refrigerators
Kenmore fr/refer 795.77553600 control panel display - Er CF, nothing when depress key
  • 8 Answers
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
Posted on Nov 04, 2008
SOURCE: control panel shows "Er dH"
The “er dh” code means a problem with the defrost cycle. It is triggered when the defrost sensor does not reach 46 degrees F within 2 hours of the defrost cycle starting. If indeed the defroster is not working, the evaporator (in the bottom of the fridge in the freezer compartment and behind a plastic cover) will eventually ice up completely, blocking the flow of cold air to the upper compartment. Use a thermometer to check the upper compartment to verify that no or little cool air is reaching it.  If the evaporator is iced up, the defrost cycle is not working. Quick fix to restore operation to the upper compartment: tape over all vent holes in the upper section to keep that cool while you work below. There are about 6-7 vent opens in the back wall and two large one on the floor of upper compartment. Remove freezer door, drawers, slide rails and pull back the plastic cover (2 screws hold it in place, one in the center and one behind the ice maker) at the rear of the freezer section to expose the evaporator. Spray hot water on the ice accumulation on the evaporator (it looks like a radiator) to melt it (remembering to sop up what flows to the drain pan at the rear). The entire operation can be done in about 30 minutes (most time is used for removing ice and sopping up water from the drain pan). All should be ok for 3-4 days depending on humidity before the evaporator ices up again.  In the meantime, order a replacement control board. You can view this by removing a panel w/ 3 screws at the rear left of the refrigerator. This panel controls all refrigerator functions, including defrost. Most likely, the integrated relay for the defrost cycle failed. Swapping out panels is a 10 minute job. Panels cost about $116 incl shipping from repairclinc.com. Shipping is about a week.  You can find a free service manual on line that will help to identify all parts and is particularly useful for removing doors and trays so you can get at the evaporator.  All in all, the customer service is useless. The fridge however is very easy to work on and amazingly simple. The replacement board has a slightly different relay for the defrost heater, so LG may have realized a problem existed with the original. It is also possible that electrical surges damaged the relay.  In any case, 10 minutes and $116 seems pretty minor to have the fridge back to new condition. Good luck.
Posted on Apr 16, 2009
SOURCE: the code er-1f displays on my control panel
the codes are listed back of your ref.and what they mean
Posted on Mar 17, 2010
sonicboomele
  • 1557 Answers
SOURCE: What does if mean when the display reads ER CF
it means there is a fault with the units compressor fan you will notice the fridge is running with less noise you will need to call a service man to come fix it good luck
Posted on Apr 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Jan 03, 2014 | Kenmore 31 cu. ft. French-Door Grab-N-Go...
I saw a word in the front is ER CF like error
CLICK
Oct 16, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
Sul display del frigo appare er pc lampeggiando
Code PC Er is saying there was a momentary power loss.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Hope this helps to solve it.
Jun 04, 2011 | Refrigerators
H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Err CF. What does this mean
er cf means one of your fans is not oper .. if compessor is on condencer motor has to be on ,.. witch is next to it has to be on . if not its bad and/or pcb board is bad /
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
