Question about Racer AcerPower F5 PC Desktop
AcerPower f5 4GB RAM only 3 available
Hi everyone, Thanks for your help on this. I have AcerPower F5 configuration with updreated bios r02-a4 (didn't saw a single oprion for RAM memory in it) I've installed 4 GB RAM (2x2GB each of them recognized separately) I know that my video card uses 256MB of that memory and i expect to see 3.75GB ram available, but no:( And since my bios does not recognize that volume of memory my windows 7 (although 64bit) is not recognizing it eather:( PLease help!
    Habit-Forming:
  • 152 Answers
In win 7 it won't shows all RAM, mostly virtual and paging file uses it,don't worry your ram is fine.when cpu require high RAM usage it uses it.
Posted on Feb 18, 2014
2 Suggested Answers
  • 10 Answers
SOURCE: RAM Upgrade for AcerPower F5
Just to make sure, you are UPgrading the RAM aren't you, it originally has 1GB in it, didn't it? Because i Hate people that change things when it is unnecessary.
But you are right it helps to look at the little label on the RAM you took out as to what kind to get, try to get the same speed will probably guarantee it will work.
Posted on Jan 02, 2009
Acerpower f2 bios beep codes
The beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM modules and Cmos battery sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
hope this helps
Jun 22, 2012 | AcerPower F2 PC Desktop
Set up bios hp compaq presario v2000
1. restart you computer and enter bios screen by pressing f1 or f10 at first screen
2. set bios as you like, or press f5 tkey to load the default bios configuration
3. select yes using arrow key, and then press enter
4. press the f10 key to save the setting and exit
5. select yes using arrow keys and press enter
for more isformation about hp compaq bios see this page
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=409741&prodTypeId=12454&objectID=c00220813
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | HP Compaq Presario V2000 Notebook
Repair XP on Acer F5 Series Towers
Go in to your computer in safe mode, use the restore feature to fix your problem
Dec 21, 2009 | Racer AcerPower F5 PC Desktop
Bios setting for acer power f5 to convert to xp
you cannot change the OS from BIOS. or are you reffering to load to XP while booting up, if you have two operating system installed. Im sorry your question is not clear
Dec 12, 2009 | Racer AcerPower F5 PC Desktop
Won't boot and doesn't even get to BIOS
You definitely have a hardware issue so you need to go through a process of elimination to figure out what it is.
1) try another video card (if you are using a video card)
2) try your on-board video (if you have it)
3) take a look at your motherboard to see if any capacitors look bulged
4) try another power supply (although the computer is getting power, it might not be getting "good" power)
Usually if it is the memory you will at least get a beep. This sounds like it is probably your mobo if it isn't your video card.
May 26, 2009 | Racer AcerPower F5 PC Desktop
Jan 02, 2009 | Racer AcerPower F5 PC Desktop
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
How to fit more ram
go into the bios.
You should have a setting that says Single channel or dual channel. Usually on the first page of bios.
If the problem persists, without being able to set the bios configuration. put 1 stick of ram in bank 1, and 1 stick of ram in bank 2.
Regards mike @ compurepair.
Mar 29, 2008 | Acer Aspire™ T180 PC Desktop
Dell webpc,,2 short beeps and keyboard error
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Mar 07, 2008 | Computers & Internet
AcerPower 1000-EA380M No Video
open the cover,try to find jumper "c-mos clear",probably is green,or red. put it on,then power on the machine abaut 3 -5 sec.then shut it down. then put the jumper in prevoius position and start macine normaly.on screen you have a note "c-mos clear,enter setup......",enter set up and chose auto configuration,save and exit and everything is ok.
Feb 04, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Racer AcerPower F5  PC Desktop Logo
60 people viewed this question
Top Racer Computers & Internet Experts
David Payne
David Payne
Are you a Racer Computer and Internet Expert? Answer questions, earn points and help others
