Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Fo error code dacor epicure - Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
5 Suggested Answers
SOURCE: how do I convert a dacor epicure range ERD48 from
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
Posted on Jan 30, 2010
SOURCE: How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
reyjoshua07
  • 1157 Answers
SOURCE: dacor oven code FO means keypad is in depressed mode
Hi minnabristol,
The F0 Fault Code Description is "Function key stuck". The only solution to this is to replace the touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Posted on May 18, 2011
reyjoshua07
  • 1157 Answers
SOURCE: Dacor oven code FO means keypad is in depressed
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Posted on Jun 08, 2011
My Dacor RSD 30S has an Error Code FO
first off you need to find the description on the code see what it stands for .then a repair issue can be looked at!
Jun 19, 2013 | Dacor Preference RSD30 Gas Kitchen Range
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Dacor Model# ERD36, Oven Element no heat & no error code flashes.
look for a hi limit thermo in burner box or on back of oven . if it has over heated this would cause this . dacor has a resetable one . it may be located on left side panel will have to be removed . ck elect sch tof location .. mm
Dec 04, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
