Question about GE WBVH6240F Front Load Washer
GE WCVH6000JOWW softner dispenser fix - GE WBVH6240F Front Load Washer
4 Suggested Answers
SOURCE: GE WSXH208AWW doesn't dispense detergent.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Posted on May 27, 2010
ginessasemai
SOURCE: My Ge Adora washer fabric softner dispenser
Dilute the fabric softener, I was told by the repair man that this is a common problem and easy fix.
Posted on Feb 16, 2012
SOURCE: Fabric softner dispenser
if the fabric softner hose was to come off at the top of the machine would it pour water out the hose during final rinse
Posted on Jul 01, 2013
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
Fabric dispenser is clogged. How do I unclog so
The dispenser is removable easily. You can scrub down the softener dispenser and it will eventually work.
Jun 12, 2010 | GE WSXH208A Front Load Washer
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
Apr 17, 2010 | GE WSXH208A Front Load Washer
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
The fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
Aug 11, 2009 | GE Washing Machines
Small brush and plain water. Rub, flush, repeat...
If it's clogged where you can't get a brush, pour very hot water into it. Last resort would be blowing it out with an air compressor...
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Jun 18, 2008 | GE WBVH6240F Front Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
