Asus troubleshooting Had a power surge and now it won't turn on
    Top Expert:
  • Computers & ... Master
  • 25,701 Answers
Try removing the 'battery, RAM and HDD. With NO POWER at all, press the power on button a few times to discharge the mother board and then refit RAM and HDD then power up with the adapter.
Posted on Feb 15, 2014
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Gas won't stop coming from oven
Hello suremoss - Once you have experienced a gas leak, I highly recommend turning the unit and the gas off if you can reach it. For safety and liability reasons we do not suggest that you troubleshoot this yourself any further and to contact a professional to move forward immediately
Dec 16, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Asus m4a87td Power Surge
Cup of coffee says it is the PS.. First item a surge hits and .......A mo bo will perform a test before it boots up and if all signal voltages are not present properly it simply will not boot up. Hope that your cmos did not get corrupted.
Aug 30, 2017 | ASUS M4A87TD EVO Motherboard
Dell dimension 3000 won't turn on
No way to teat but to install another PS.
Jul 31, 2012 | Dell Dimension 3000 PC Desktop
Tv won't turn on due to power surge
It's technically possible, but depends on the damage.
Jul 01, 2012 | Televison & Video
Asus desktop won't turn on
In most cases the power supply module is the cause of no power, replacement is the recommended approach.
Apr 18, 2012 | ASUS Computers & Internet
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
