Question about Pioneer FH-X700BT
Illumination to bright
Stereo face illumination to bright
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
How do i get lites on face they are dim
Check your car battery. Try to turn off your headlights and aircon then look at your stereo if its bright, if it has bright light try to turn on your aircon and headlights then if the light of your stereo turns dim the problem is now on your car battery. The battery cannot supply all the electricity needs of your car.
Jun 28, 2011 | Jensen CD-4010 K CD Player
I need to know wat the orange wire is on a 2004 dodge ram 1500 stereo
If it is an orange wire with white trace, this wire is used for dimming the brightness when you turn the lights on.....normally connected to the illumation wire...sometimes to the cig lighter illumination or dah illumation wiring........
Dec 20, 2010 | 2004 Dodge Ram 2500
Display dosnt work at all. it plays music fine i just dont see anything on the screen.
look and see if the yellow illumination wire behind the stereo is connected to the power wire, you may not have its lights wired up, this could cause you not to be able to see a display, to test this for sure shine a bright flash light into the face while its playing, if you see some display, this is the problem
Sep 24, 2010 | Sony CDX-F7000 CD Player
AC display won't dim after stereo installation
If you disconnect the stereo, does the temp. display go back to working properly? Did you connect the stereo Illumination wire correctly? Are all the other stereo wires connected correctly? Double check what the wires in the aftermarket harness are supposed to be and don't just go by color.
Jun 17, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Stereo reciever takes several seconds to power up
The power switch is arcing internally and needs to be replaced. This is a common problem with some older receivers. Sometimes the switch can be opened and the contacts burnished.
Dan
Mar 02, 2009 | Audio Players & Recorders
Face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
May 04, 2008 | Panasonic CQ-DF802U CD Player
Orange = Illumination
Some vehicles have an illumination signal that tells the stereo when your headlights are turned on so that it can dim the display (to help keep from being blinded by overly bright stereo displays at night). If you don't have that signal, don't connect the stereo wire to anything.
Mar 28, 2008 | Pioneer Premier DEH-P580MP CD Player
TEAC SR-L100
hi i am from mongolia
Jan 09, 2008 | Audio Players & Recorders
No face illiumination
that backlight has failed and replacement not cheap
May 28, 2007 | Jensen KDC-9520 CD / Cassette Player
Pioneer FH-X700BT Logo
41 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
