Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Hydraulic failure My TE20 hydraulics have stopped working. They will not lift gthe arms.This happened sudenly. PTO and oil levels are fine.
    Problem Solver:
  • 8 Answers
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Posted on Feb 16, 2014
Where is pto over temp relay or sensor located on x495 john deere diesel engine
I worked for Kubota for 10 years and I am not familiar with a PTO temp sensor, John Deere or otherwise. The PTO function has nothing to do with engine other than slight increase in coolant temp when the PTO is under a load. Check for correct Hydraulic oil level(dipstick or sight glass in transaxel) and make sure grass or trash is not packed around the hydraulic oil cooler in front of the radiator. Remove the screen and use compressed air to clean it often. Change hydraulic oil filters every 100 hours
May 21, 2017 | Cars & Trucks
Yanmar b15 excavator Boom and arm will not operate. everything else works fine. HELP.
Is there an interlock on the boom that wont allow it to operate if the front blade is not set? There could be an issue with hydraulic fluid, pump or PTO.
Feb 08, 2017 | Cars & Trucks
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
Why front bucket nor rear lift arms will not move?
by your description im assuming that your rerfering too a tractor , with it seems none of your hydraulic implements that move, i guess first thing to ck is proper fluid level in hydraulic res tank (not confused with engine oil) second is to make sure hydaulic pump is turning some tractors use a Pto drive shaft right off the transmission or front of engine and others use a belt that drives off the water pump need to ck all these things
Aug 28, 2014 | Cars & Trucks
1986 530 international loarder
Did you check oil level in hyd resivor it might be low also check fuses.
Nov 19, 2013 | Motorcycles
M-f 35 exhibits jerky motion on hydraulic lift and front loader
Check the rear end oil level. Failing that try cleaning the hydraulic oil fillter.
Oct 23, 2013 | Massey Ferguson Aux Hydraulic Pump
I have a john deere 318 and my pto doesn't work as
check for hydraulic oil level in the pto pump
Jun 04, 2013 | Garden
Ford 9n 3 point will not lift
Hey Chris..my name is Keith..and i restore 9N's,2N's and 8N's ..and i can help you with your hydraulic problem...the most probable cause is the hydraulic safety relief valve and i would change that 1st..the part number for it is..8N-638..and they cost about 25 dollars..and to change it..you either jack up the rear axle or you part the tractor down hill..so the hydraulic fluid goes to the front..and then you open up the side cover..that has the dip stick in it and unscrew the Safety relief valve from the hydraulic pump9located on the back side of the pump)..and install a new one..and have plenty of rags..because it is a mess job..and if you dont want to opent that cover again..i would replace the hydraulic control valve..part number 9N-640..is costs about 35 dollars and its on the back side of the pump also..and dont forget to get a new cover gasket and that part number is 9N-4131 and it costs about 1 dollar..i hope this has helped..if not write me back and we will get into the hard stuff on the hydraulic system
Mar 15, 2009 | Ford Garden
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
550 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
