Question about Whirlpool Washing Machines
Maytag Bravos washing machine is very loud on spin cycle. Sounds like a jet. Changed the drive motor cause of oil spatted all over the belt and motor and stopped on spin cycle. Replaced motor and main barrell still sounds loud. How do I change the spin beaing for the main barrel
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Posted on Apr 11, 2009
  • 92 Answers
SOURCE: Machine locked up. Barrel quit spinning.
first you got to empty washer by manual,get a bowl on to the floor then pull the drain pipe out of the pipe that goes outside or from under the sink,empty washer this way then the door will open,as it wont open as a result of it having water in it,when you have done this make sure you check your motor bushes,im sure that they have worn,just replace them at a cost of £10.00,they are easy to replace.rgrds paul
Posted on Jul 07, 2009
  • 215 Answers
SOURCE: Hotpoint washing machine barrel not turning all
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Posted on Feb 11, 2010
SOURCE: My washing machine washes through
Hi, well, yes well indeed this is some sort of "Connection" problem, it seems that the center "Drive" and the "Tub" aren't connected as they should be.
If you wish to DIY, then you simply MUST obtain a service manual for your exact make and model. This will show you how to troubleshoot and the steps to take to isolate the problem and repair, also those all important spare parts numbers.
However, based on my experience, most likely the best option and the cheapest in the end, would be to contact your local or head office of your manufacturers, and ask for a referral to an authorised service center and then, ask them to call and give you a "Quote" as to the cost and type of repairs needed and then go from there...
Posted on Jun 14, 2011
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Maytag bravos quiet series 300. When input a load of clothes in it will get loud during spin cycle and now won't finish because codes ul. Sounds loud like a bearing
You are spot on. If there is a lot of movement in the drum (>5mm) then it'ds the drum bearings (big job) but check the motor bearings too as much easier to fix.
Dec 08, 2013 | Washing Machines
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
