Question about Acer Aspire 7720 Notebook
My acer 7720 won't boot up
My acer won't boot up
What are the key functions on top of my acer aspire 7720
Hi Shawna
From the owners manual for the 7720, (Page 15) all of the functions of the buttons are listed. Just cut and paste this address into your browser.
ftp://ftp.acer.at/notebook/aspire_7720/manual/Aspire_7720G_7720_EN_McAfee.pdf
Hope this helps you out.
-Steve
Apr 02, 2015 | Acer Aspire 7720 Notebook
NUMERIC KEYPAD NOT SUPPORTED
Might give this a try-right click on your Computer icon-click on Properties-then click on Device Manager. The keyboard is listed there. If it has a yellow exclamation point, or a yellow question mark, then there is a problem. Click on the arrow in front of Keyboards, then right click on the drop down named keyboard. There you can click on update drivers. That should solve the problem.
May 07, 2014 | Acer Aspire 7720 Notebook
Acer Aspire 7720 beeps after awhile
If it continuously beeps after every while, must be you have some alert on software running on background, check , could be temp alert, or if you have any antivirus software, it also leads to beeping whenever it finds a virus(sometimes). Hope this helps.
Dec 15, 2013 | Acer Aspire 7720 Notebook
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
The keyboard & mouse seemed to have locked up my acer aspire 7720, can't get any futher select user screen?
you can use the usb keyboard...also try your computer in safe mode and check the status.
you can get into safe mode by pressing/tapping F8 at the time when computer starts.
if you presses the key at the right time you will be directed to the page which says Advance boot option...you can select safe mode with networking so that you can connect to internet
Aug 11, 2011 | Acer Aspire 7720-4428 Notebook PC
How to Remove an Acer Hard Drive
dont need to remove the hard drive to make it boot up
what screen activity do you have when the machine starts
do you have a power light or battery light when the charger is plugged in?
do you get the start up screen when you press the start button?
We may be able to recover this unit using the eRecovery process,
(preinstalled on your laptop by ACER)
Please give me as much details as you can and I will tell you what you need to do from there
if thats any help
Thanks Misterdj
May 06, 2010 | Acer Aspire 7720 Notebook
The Numeric keypad on my Acer Aspire 7720 doesn't work. When I press Num Lock key the indicator light doesn't come on. The main keyboard works fine. I am using Vista.
try to access command prompt outside of windows using the operating system disc. (by booting to cd and go to repair your computer options then select command prompt) if the keyboard works fine on command prompt, there's no issue with the hardware. but if it still doesnt work, you will need to replace the keyboard.
Dec 03, 2009 | Acer Aspire 7720 Notebook
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
Acer notebook 7720
if its brandnew, take it back, its under warranty !
Dec 12, 2008 | Acer Aspire 7720 Notebook
Acer Aspire 7720 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
