SOURCE: Need double link for mini Ebel Classic Wave Watch
Unfortunately you will not be able to buy links anywhere else exept Ebel. You can try to find them on eBay, but it may take years and even then there is no any guarantee thet you will find the right links.
The best way is to contact Ebel and ask them if they can supply any links needed. Visit this link:
http://www.ebel.com/#Stores_Service_Centers
Choose the way you want to contact them or the nearest srevice center.
Do not forget to rate, please.
SOURCE: I have just received my
Yes for sure you must not accept a damaged piece as your money should be worth for a new one. so contact the supplier and make you point clear, take a photograph of the damaged watch and mail to them to confirm before you send it back as if their representative can call on to address the issue.
Make it also clear that there was irresponsibility that the instruction leaflet was also not inside the box.
SOURCE: I have a ceramic akribos watch and the butterfly
I suggest you have to pop in to your nearest watch repair shop and ask watchmaker to take a look at clasp first.I t is impossible to tell if the clasp is repairable or not over the internet, as there are plenty of possible causes to make it pop open. If the watchmaker will tell you that there is no chance to repair it, then you will need to contact AKRIBOS yourself. Here is the link to contact AKRIBOS: http://www.akribos24.com/#/contact At the right bottom corner of the screen you will find AKRIBOS phone number. Good luck and I hope it helps.
