Question about Konica Minolta bizhub Office Equipment & Supplies
Printer won't work.
Error code 1139c. won't reset
  • Konica Minolta Master
  • 6,161 Answers
Paula what is the model of the machine?
Posted on Jan 30, 2015
Canon pixma 922 won.t print..computer says not printer not responding also says printer in error state..no printer codes showing
Depends on if you have it set up correctly for proper port config. Is it set up for USB or LPT? Check it out with PRINTERS showing printer details on driver etc.
Feb 23, 2015 | Canon PIXMA Office Equipment & Supplies
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
We have a Canon imageClass D860. It came up with the error code E000. We have unplugged several times and left unplugged. When we plug back in, the error message is still there. Have any answers?...
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press Unplug printer and repower it.
Oct 11, 2010 | Canon ImageClass D880 Copier
How do I get a new mp830 waste ink absorber for my mp830 printer?
The "waste ink absorber" in these models is just a length of cotton inside the printer that absorbs the waste ink. Usually they are rinsed and dried and replaced, and the printer is reset. I do not know of anywhere to get new ones
Sep 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Feb 19, 2007 | Canon Pixma iP6000D InkJet Photo Printer
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
