Question about Electronic Arts NASCAR Thunder 2004 for Windows
Nascar Thunder 2004 not working in windows 8
The installed program fails to detect the installed EVGA video card and has issues detecting system memory.
Lost install code for nascar thunder 2003
Sorry, but we are not a warez site. We don't give out activation keys or password codes...
Jul 12, 2012 | EA - Electronic Arts NASCAR Thunder 2003...
When i install the game, the graphics of the cars are all distorted. how can i fix this? I'm running it on windows 7. Will it have problems running on windows 7?
Right click on the executable file for the program, select Properties. In the resulting window, select Compatibility, then change it to Windows XP.
To find the executable, right click on the icon and look at where it says the shortcut leads, then navigate there in Computer Explorer.
You might also find a config utility in that folder, or in the options menu.
Jul 05, 2011 | Electronic Arts NASCAR Thunder 2004 for...
I have a motherboard with an Integrated ATI HD 4200. When I install my EVGA GeForce 8600GT the fan runs but the card itself is not detected in device manager or anything like that. I disabled the onboard...
You don't disable it from there. Reenable it again and do it right: you uninstall its drivers from Programs and you reboot twice; you install the new card and you connect the monitor to it; when the pc starts you go directly in the BIOS and you disable the onboard card from there; you reboot one more time and you install the drivers for the new card.
Feb 26, 2011 | Evga e-GeForce 8600GT, GeForceĀ® 8600 GT, ...
My computer using windows 7 cant detect my new video card, (evga geforce 9500 gt, when i turn on my computer i tried connecting vga with the dvi adaptor to my graphics card but that doesnt work, i saw...
Hi drago,
You can find your drivers here:
http://www.evga.com/support/drivers/
Download the drivers you need, and install them manually in the Device Manager.
In Windows 7, goto the Device Manager (click on Start, right click on My Computer, left click on Properties, click on Device Manager) Look for your video cards, click on the + to see which ones are installed.
Once you have the new drivers installed, you may have to uninstall the integrated graphics drivers to force Window to use the new card.
Hope that helps
Dec 25, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
I need the installation codes for Nascar Thunder
my mobile china model no.s90 yor china sigmatel pls onily f
Dec 14, 2009 | EA Sports Video Game Consoles & Games
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
NTLDS missing when installing windows 7
Before tring to install Windows 7 I suggest you download (or your in law) from Microsoft a utility program that detects your hardware and tells you whether the system will support this RC version of Windows. Download "Windows6.0-KB947821-v4-x86 Update Readiness.msi" and run it on the system prior to installation. If your system is already damaged, install a base WinXP OS on it and try it. Good luck!
Aug 16, 2009 | Microsoft Computers & Internet
Asus P5N-E SLI Motherboard and Ethernet Controller Problem
Had a similar problem with P5ne-sli motherboard, Intel Q6600 cpu, Nvidia GTS 8800 video card. One day the ethernet just stopped working, but it was working... It would connect to my network but would see "limited or no connectivity" in the taskbar. Went into BIOS and looked at the signals and for some reason only 4 of the 8 signals were getting a reading. Figured a power spike had fried my onboasrd ethenet card. Switched to an old PCI ethernet card... after two years I was doing a fresh install, of XP and for shits and giggles I just plugged the ethernet cord into the onboard with the PCI ethernet card removed. When windows went to validate it detected and installed my onboard ethernet...validated then proceeded to update windows. Over a year later it still works.
Never bothered to update BIOS until last month and that was only to fix the long boot time with ATI 5770 video card.
Willing to bet that resetting your BIOS will fix the problem for you. Just unplug computer, remove battery, attempt power up to clear any juice still in the system. Replace battery and boot up computer...
Also removed a DIMM that went bad around the same time. May have been a factor so try testing your RAM.
Jul 13, 2009 | Evga GeForce GTS 250,, PCI Express Video...
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
PCI-E Slot Not Detecting the Video card.
It maybe a problem with the installation cd. You can either go back to the seller and ask the appropriate installation cd or you can just download the driver through the net.
Sep 21, 2008 | E-Machines Computers & Internet
Electronic Arts NASCAR Thunder 2004 for Windows Logo
62 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
akigawa
Level 1 Expert
James Wishart
Tom Chichester
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
